homemade electronic map limiter.... anyone else using one?
Old May 20, 2002 | 11:06 PM
schwett's Avatar
New User
Default homemade electronic map limiter.... anyone else using one?
with the help of some po.com guys, i made this lil' gadget :
if it works as designed, it will pass through the map signal essentially unchanged, until it reaches 2.8v (adjustable with the pot), at which point it clamps it. it's three resistors, a voltage regulator, and an op-amp. i don't really understand how it works except in the most basic principle.
i'm going to solder on and heat shrink some proper wires with bullet connectors and then put it in a 3/4" x 1/2" x 2 1/2" housing. i made another one based on a much more complicated design, with a relay, but i think this one is nicer!
hope it works.
Old May 20, 2002 | 11:15 PM
turbopanda's Avatar
Default Re: homemade electronic map limiter.... anyone else using one? (schwett)
I used to use one in my Civic, but it wasn't home made, it was produced by Link called "ClampLink" which did practically the same thing, and could be adjustable. They work well, no more damn checkvalves!
Old May 20, 2002 | 11:16 PM
schwett's Avatar
New User
Default Re: homemade electronic map limiter.... anyone else using one? (nathan's boosted civic)
sweet - i'll have to check that out. how much was it?
Old May 21, 2002 | 12:53 AM
ImportHatch's Avatar
damn thats pretty tight....post up some prices.
Yager-
Old May 21, 2002 | 01:41 AM
turbopanda's Avatar
Default Re: homemade electronic map limiter.... anyone else using one? (ImportHatch)
click on the "link engine management" link in my signature, its somewhere there on the site.. probably under accessories or options.
Old May 21, 2002 | 05:24 AM
5 Liter Eater's Avatar
That's pretty neat Schwett! I'll bet you test satellite equipment too huh?
Old May 21, 2002 | 06:39 AM
xci_ed6's Avatar
Default Re: homemade electronic map limiter.... anyone else using one? (5 Liter Eater)
Cool, could you get a diagram of that? I want to make one but it is hard to sort out the conections, and I can't read the third color band on one of the resistors.
-Dustin
Old May 21, 2002 | 06:47 AM
CovertFI's Avatar
do you have a sketimatic for that? i want to build one!!
Old May 21, 2002 | 07:08 AM
falcongsr's Avatar
What is this crap?
thats a nice little voltage clamp circuit. i bet thats very similar to what the J&S v2 has in it.
Old May 21, 2002 | 09:02 AM
schwett's Avatar
New User
i checked the link site... didn't see it... but i do see it on the one in your sig. what does it look like? $70 isn't too bad i guess. same as a missing link.
the one i made cost about $5-10 though, but i have yet to see if it works. here's the schematic, but nobody go build one until i can test it! it would be a bummer if 4 or 5 of us built the same non-working voltage clamp. heh.
notes from the designer : The op amp is set up so the output follows the input 1:1. R1 and R2 set the reference of the TL431 so that when + input on the op amp reaches 2.8V, the TL431 will start to conduct and limit the voltage to 2.8V. R3 drops the voltage when the TL431 is conducting, otherwise R3 would drop a maximum of 9 microvolts. Also, if the input in the ECU is high impedence, you probably wouldn't even need the op amp in the circuit I drew. I really doubt the op amp is even needed.
If the input inpedence of the ECU were not high enough, you would have voltage drop on R3 even when the TL431 is not conducting. That would mean the ECU would always see slightly less voltage than what the MAP is sending.
Also, replacing R1 with a 20K pot would make this circuit adjustable.
[Modified by schwett, 10:06 AM 5/21/2002]
Old May 21, 2002 | 09:47 AM
turbopanda's Avatar
http://www.carmodifications.com/Link...ink-tuning.htm
its the last device listed on the page, "MAP sensor ClampLink" - same thing that I had running in my Civic. Works brilliantly, and voltage is adjustable by using a screwdriver and multimeter).
probably the schematics to your own version would work well.. just get it tested, and let us know of the results!
Old May 21, 2002 | 11:15 AM
JMinSi2000's Avatar
So, whats the point of this thing? What does it do? Sorry I'm dumb.
Old May 21, 2002 | 11:38 AM
Sonny's Avatar
Default Re: homemade electronic map limiter.... anyone else using one? (JMinSi2000)
If the MAP sensor "sees" boost, it will cause the ECU to throw a code. The map limiter circuit allows the sensor to see boost, but it will clamp the voltage going to the ECU so that a code will not be thrown. Adjusting the max voltage seen by the ECU from the MAP sensor is also a way of controlling injector duty cycle at WOT.
Sonny
Old May 21, 2002 | 12:41 PM
JMinSi2000's Avatar
Default Re: homemade electronic map limiter.... anyone else using one? (Sonny)
So is something like this pointless with a standalone?
Old May 21, 2002 | 01:10 PM
schwett's Avatar
New User
for the most part, yes.
hondata, for example, modifies the ecu program to see and accept boost.
the pms, on the other hand, uses a separate 3 bar map sensor to adjust fuel for boost, and just passes the original signal along to the stock ecu unmodified.
Old May 21, 2002 | 01:33 PM
CovertFI's Avatar
so when are you goning to test this out
Old May 21, 2002 | 01:36 PM
schwett's Avatar
New User
Default Re: homemade electronic map limiter.... anyone else using one? (CovertFI)
with some batteries and a voltmeter, tonight... for real, next week some time. built motor getting dropped in in a few days. [fingers crossed]
Old May 21, 2002 | 02:46 PM
EE_Chris's Avatar
Your using a 7805, which is a 5V regulator. You make no mention of this in the schematic (although you do mention it in your initial post).
Care to fill us in?
Old May 21, 2002 | 02:59 PM
schwett's Avatar
New User
Default Re: homemade electronic map limiter.... anyone else using one? (EE_Chris)
yep, that's a mistake. i thought the tl431 was a 5v regulator. it's not. i need to switch that piece out.
Care to fill us in?
[Modified by schwett, 4:03 PM 5/21/2002]
Old May 21, 2002 | 03:01 PM
EE_Chris's Avatar
Yeah, the TL431 is defenitely not a 5V regulator. Thanks for the clear up.
EDIT: But it is a regulator no less.
EDIT 2: Perhaps a better Vref for the TL431 would be the output of the BARO sensor. From what I've read, to generate a MAP code (from boost), really means to exceed the BARO output. Just a thought.
[Modified by EE_Chris, 7:53 PM 5/24/2002]
[Modified by EE_Chris, 7:57 PM 5/24/2002]
Old May 24, 2002 | 11:58 AM
JM Performance's Avatar
bump.
want to see how its going
Old May 24, 2002 | 12:18 PM
apexii's Avatar
looks like one of Gabes ideas!
Old May 24, 2002 | 01:26 PM
falcongsr's Avatar
What is this crap?
Default Re: homemade electronic map limiter.... anyone else using one? (00SilverLS)
bump.
yeah me too. i have some oscilloscope traces of the J&S map limiter circuit. i would like to see some traces from this circuit also. someone wire it up and take pics with a scope!
Old May 24, 2002 | 02:37 PM
schwett's Avatar
New User
haven't had time to check it - work sucks.
i will definitely be testing it out this weekend though. very interesting idea hooking it to the baro circuit for a reference.
bump.
Old May 25, 2002 | 06:41 PM
schwett's Avatar
New User
Default strange results!
i replaced the 5v regulator with the specified regulator. (used an nt999, equivalent to the tl431. first i tested it with a 3.15 volt input. adjusting the pot, i got the output to 2.83v. so far so good. tried it with 4.35v input, got out the same 2.83v. tried it with 8.11v, got the same 2.83v.... all good!
but then i tried 1.21v, and the output was.... 1.38v! WTF! i tried 1.57v, and got 1.44v. i have no idea what the problem is. i don't have anything that will supply a <1v input, so i don't really have a good range of results for the "1:1" condition.
