holley throttle bodies
Old Nov 25, 2002 | 07:26 AM
98civicEX's Avatar
Default holley throttle bodies
shouldn't the throttle bodies be interchangeable between the b-series and d-series, they have different part #'s, but i don't see why they shouldn't be interchangeable...can anyone speak from fact on these?
Old Nov 25, 2002 | 07:28 AM
GraphiteAccord's Avatar
Default Re: holley throttle bodies (98civicEX)
most all TB's can be exchanged...my H22a TB will fit a D16....
Old Nov 25, 2002 | 07:39 AM
ekb18c's Avatar
Holly TB's tend to stick! Or atleast, the few I have install have been sticking. I installed one and it was sticking. Ok, NP I got another one and it was sticking too. arggg
Old Nov 25, 2002 | 08:07 AM
Marauder's Avatar
All of the B and D series are completely interchangable! The difference between them is the throttle arm, and the way the throttle linkage should be connected to them.
The bolt patterns and IAC port location on the manifold are all the same.
The 6th Gen civics have the same throttle linkage as Integra Type R's. So if you have a built motor in a 96-00 civic, and want a large throttle body....pick up a aftermarket Type R!
I just wouldn't pick a Holley part. They company isn't doing so well anymore, and is facing bad money problems. Go with someone else's throttle body!
Old Nov 25, 2002 | 08:16 AM
Boostfed's Avatar
New User
Just FYI I have a 68mm Holley for Sale $250 plus shipping. It does stick too as ek mentioned above.
Old Nov 25, 2002 | 09:10 AM
Smashback's Avatar
Default Re: holley throttle bodies (Marauder)
BBK sucks as well. Stuck like a ****...now I have to use a '00 Si tb. Better than stock, but it sucks after having the manifold matched to the 62mm.
Erick's TBs get a lot of praise, might want to check into those.
Old Nov 25, 2002 | 11:04 AM
paulzy's Avatar
Default Re: holley throttle bodies (Hatchblack)
My cousin has one as well...it dosen't stick, but the plate will not close enough at idle
Old Nov 25, 2002 | 11:40 AM
Smashback's Avatar
Default Re: holley throttle bodies (paul_vang)
Mine would close at idle....if you got out and pushed on it. It would even stay like that....until you hit the gas again at least.
toolbox21
Nov 27, 2008 10:21 AM
JeffBro
Jun 26, 2006 05:58 PM
DevinW
Sep 3, 2002 07:18 AM
