HKS FUNNY NOISE.......
Old Apr 7, 2005 | 08:58 AM
Drkaccrd's Avatar
Default HKS FUNNY NOISE.......
All right all you HKS SSQ owners my bov is making this bubblely flutter sound when I let off at lower rpms (1000 to 3000 rpms).. It sounds pretty gay. Do any of you think that tightening the HKS adjustment screw would make a difference? It didnt do this till just recently. I checked for loose clamps. I found nothing. Anyone with suggestions?
Old Apr 7, 2005 | 09:52 AM
Drkaccrd's Avatar
Default Re: HKS FUNNY NOISE....... (Drkaccrd)
BUMP TO THE TOP PLEASE........
Old Apr 7, 2005 | 11:20 AM
T Dohc's Avatar
Just play with the 10mm bolt till it sounds ok to you (turning the bolt in tends to kill some of the flutter at low rpm, low boost but every car seems to sound a little different)
hope this helps
Old Apr 7, 2005 | 11:24 AM
Benjithx's Avatar
Default Re: HKS FUNNY NOISE....... (T Dohc)
yep, tighten it up a bit
Old Apr 7, 2005 | 11:28 AM
shadow103rd's Avatar
to me it sounds like your getting surge...looseen it up
Jon
Old Apr 7, 2005 | 11:45 AM
Drkaccrd's Avatar
Default Re: HKS FUNNY NOISE....... (shadow103rd)
Ok now Im confused....... Two responses say tighten. One says loosen. I guess try'em both??? From what Ive found out about compressor surge so far is prior to the bov opening up you hear a metal like sound, I only hear this sound when I'm letting off the throttle. Imagine if you will light throttle release and you hear underwater like bubbles being released. Thats what I'm hearing at light throttle
Old Apr 7, 2005 | 11:53 AM
dustin's Avatar
If you are at full boost... and let off the throttle entirely... what sound does it make?
Old Apr 7, 2005 | 12:09 PM
Drkaccrd's Avatar
Default Re: HKS FUNNY NOISE....... (dustin)
A sharp high pitch sound. I guess normal HKS SSQ style.
Old Apr 7, 2005 | 12:10 PM
dustin's Avatar
High pitched "woosh" sound? Like it's supposed to?
If so you can tighten the bolt up a bit if you really want. Sounds like you BOV is doing what it is supposed to. HKS SSQ is noisy at atmospheric pressure/the edge of positive pressure.
Old Apr 7, 2005 | 12:16 PM
Drkaccrd's Avatar
Would a change on the intake filter of the turbo alter the sound as well?
Old Apr 7, 2005 | 12:17 PM
dustin's Avatar
No.
Old Apr 7, 2005 | 12:28 PM
Drkaccrd's Avatar
So tighten the bolt to alter the sound and a find a sufficient vacuum source.
Old Apr 11, 2005 | 10:40 AM
Drkaccrd's Avatar
BUMP.......ANTOHER QUESTION
Old Apr 11, 2005 | 10:49 AM
Drkaccrd's Avatar
After visual inspection and hitting the throttle at idle both the primary and secondary valves open if you tap it to like 2000rpm. I Thought the secondary was supposed to open under a heavier load/boost???
Old Apr 11, 2005 | 11:42 AM
Drkaccrd's Avatar
BUMP TTT.....
Old Apr 11, 2005 | 04:41 PM
nfn15037's Avatar
How about trying to adjust the little 10mm bolt? I mean, all this posting and blah blah blah'ing and you could have walked outside, adjusted it and tried it out.
Old Apr 12, 2005 | 04:29 AM
Drkaccrd's Avatar
Default Re: HKS FUNNY NOISE....... (nfn15037)
Yeah true.......I felt pretty dumb when I saw that and tried adjusting it. Hey I'm orginally from Boston, Ma. You boosting up there?
Old Apr 12, 2005 | 10:40 AM
nfn15037's Avatar
Sure am, the weather is gettin gnice and I have had the car out a few times, she was sleeping all winter......damn salt!
Old Apr 12, 2005 | 12:49 PM
Drkaccrd's Avatar
What part of Boston?
Old Apr 12, 2005 | 02:13 PM
nfn15037's Avatar
Watertown Square is pretty close to me.
Old Apr 13, 2005 | 04:45 AM
Drkaccrd's Avatar
I use to live in dorchester almost a big chunk of my life.
Drkaccrd
Apr 7, 2005 09:10 AM
Integra_Boi
Sep 15, 2002 08:03 AM
teg2snbtrbd
Apr 15, 2002 02:36 PM
SIK IN DA HED
Jul 2, 2001 06:57 PM
