HIGHEST HP with AC remaining?
Old Jul 23, 2011 | 02:46 PM
Skip01's Avatar
Default HIGHEST HP with AC remaining?
Any builds with AC still in tack and working?
List mani and build if u would...or if you know of someone.
Trying too get an idea before i go down the boosted AC road
Old Jul 23, 2011 | 06:27 PM
maxwellmercer's Avatar
Default Re: HIGHEST HP with AC remaining?
Possibilities are endless, that's why they call them 'custom' manifolds.
Old Jul 24, 2011 | 07:47 AM
sp00led's Avatar
I have a T3 Full race manifold that has a gt3076r making 550whp. I could run a gt35r and make 650-700whp I suppose. The biggest downside is the equal length AC manifolds really put your compressor housing facing in an angle right towards the radiator. That doesn't leave much room for cooling.
Old Jul 24, 2011 | 09:00 AM
Skip01's Avatar
Got any pics?
Only one i seen was the Quick4 from Spoolin.....thats made for AC
Old Jul 24, 2011 | 10:18 AM
SovXietday's Avatar
If you really want an AC manifold with a big turbo you will need to have it completely custom made. Pick a turbo, give it to a good fabricator with your car and let them build you a setup that fits.
Oorrrr... just get comfortable with sweating.
Old Jul 24, 2011 | 10:32 AM
LocoJoe's Avatar
100% true. I made 536whp@31psi on a B16 with an ebay "GT35" AC and PS and full 3' exhaust to the back. Getting a real turbo soon so those numbers will rise hopefully
I had my manifold made and thats the biggest problem I've got, High IATs. I think a water/meth kit would help in my case. Another obstacle is the close proximity between the downpipe and AC compressor. I got my 3' DP thermowraped for whats that worth.
Another option is to make the manifold bent to accomodate the compresor housing to the right using top mount style but the AC panel is gonna be a problem. Believe me I tried...
Old Jul 24, 2011 | 10:46 AM
Turbo-LS's Avatar
I'm making 406 in a dc chassis wig ac and ps. Spa top mount manifold it's agarrett diesel turbo it's an e cover t3/t4 with 60.5mm inducer and a big turbine wheel. Spools well and make good power. Love my spa top mount.
Old Jul 24, 2011 | 12:30 PM
digital sol's Avatar
what did you have to modify for that manifold to retain ac?
knotch the block or compressor at all? Run custom lines?
Any more details would be greatly appreciated, thanks guy
Old Jul 24, 2011 | 03:28 PM
Turbo-LS's Avatar
Just had to bend the stock lines a little bit to fit that's all. Nothing has to be done to
The block. If you don't use the clocking flange it might still work but might need
Modify the line
Old Jul 24, 2011 | 05:38 PM
sp00led's Avatar
Originally Posted by Skip01
Got any pics?
http://www.hondatuningmagazine.com/f...ly_modify.html
Old Jul 24, 2011 | 06:02 PM
DelSolMarine's Avatar
I am going for 700whp with E85 in a few months with AC and power steering... ID2000s and dual intank pumps....
Old Jul 25, 2011 | 03:21 PM
rs250nut's Avatar
This is with a t3 6765bb on a full race mani fits on the motor with a little grind on the block, not sure about radaitor clearance though I have not tryed it
Aiming for 700whp+
Old Jul 25, 2011 | 10:30 PM
Zer0_SpeedWorks's Avatar
numbers on my sig with ac and ps
Old Jul 26, 2011 | 08:33 AM
sp00led's Avatar
rs250nut, I would love to see your intake/filter setup once you put the radiator in. I have a PWR civic radiator that is thinner than a KOYO. That compressor housing looks nice a funky angled like mine. Looks like we have the same FR mani but I'm sure mine is an older version. Angle looks the same though.
I was able to get a guy to make a 4" intake pipe and put a K&N filter on it. That left room for a 10" SPAL slim fan and it's such a tight fit you damn near don't need fan zipties to hold it in.
Old Jul 26, 2011 | 11:28 AM
wunfstgsr's Avatar
Loved
Community Favorite
Im running a pro charged supercharger on my ITR setup making 275hp @7psi going to shoot for 450hp @15psi still retaining a.c and p.s, not a turbo but similar.
https://honda-tech.com/forums/forced-induction-16/anyone-ati-pro-charger-b-series-chime-2942111/
b18sihatch
Oct 1, 2006 06:14 PM
Sic_DA_Nine
Sep 27, 2006 01:23 PM
delsolnewkid
Apr 1, 2006 06:12 AM
sxecustoms
Oct 18, 2003 09:29 PM
Soon_2b_evil
May 9, 2003 04:20 AM
