highest amp spal fan possible?
Whats the highest amperage spal fan you can use on a integra stock radiator without popping fuses? Im looking at this as a suitable replacement for when i mount my header.
http://www.spalusa.com/store/main.as...&item=30101504
Get your self a zirgo 14" fan. That's as big as you can go without taxing the electrical system. If you want to draw higher amps then I would highly suggest using the stock power wire as a remote turn on and run heavier gauge wiring and a relay to the battery and fan
1baddturbosi
10
Nov 18, 2007 04:19 PM
Tetronious
Mar 6, 2005 04:11 PM
