High-Temp flat black manifold paint?
Old Jan 17, 2006 | 04:43 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default High-Temp flat black manifold paint?
I'm picking up an equal-length turbo manifold soon, but it looks nasty. I'd like to coat it or paint it black, for looks and underhood heat reduction as well.
What are my options for PAINT? I know I can send it to Performance Coatings or whatever, but I'd like to take care of it locally if possible.
EDIT: Here are some pics of the culprit (with the SC50 I'm getting). This thing is NASTY!
Modified by boostincoupe at 1:12 PM 2/25/2006
Old Jan 17, 2006 | 04:44 PM
platinum00's Avatar
Default Re: High-Temp flat black manifold paint? (boostincoupe)
its going to be hard with the heat of the manifold
but if its preped right. the VHT pait works pretty good.
platinum.
Old Jan 17, 2006 | 04:46 PM
Default Re: High-Temp flat black manifold paint? (platinum00)
Maybe I should just ship it to TheShodan to get coated...
Old Jan 17, 2006 | 04:49 PM
ineedhelp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe &raquo;</TD></TR><TR><TD CLASS="quote">Maybe I should just ship it to TheShodan to get coated... </TD></TR></TABLE>
does anyone know how much he usually charge to coat a manifold? he never responded to my PM.
Old Jan 17, 2006 | 07:46 PM
I want it to look like this when all done. Functional, yet it would also match my intercooler piping
Old Jan 17, 2006 | 08:33 PM
ineedhelp's Avatar
how much does that cost?
Old Jan 17, 2006 | 08:36 PM
Default Re: High-Temp flat black manifold paint? (ineedhelp)
I'm still trying to figure that out...
Old Jan 17, 2006 | 08:55 PM
project dc2's Avatar
hit up the shodan
somethign like that i THINK** is aroudn 180-200$
Old Jan 17, 2006 | 09:00 PM
Default Re: High-Temp flat black manifold paint? (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">hit up the shodan
somethign like that i THINK** is aroudn 180-200$</TD></TR></TABLE>
The manifold is $250.
BROKE STUDENT HERE, PEOPLE!!!
I'll stick to rattle cans
Old Jan 17, 2006 | 09:22 PM
I'll stick to rattle cans </TD></TR></TABLE>
rattle can wont hold up .
Old Jan 17, 2006 | 10:07 PM
broketuner-Sol_Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">rattle can wont hold up . </TD></TR></TABLE>
I don't know how hot temps get on a turbo mani. but dupli-color has a 1200' F rated spray with ceramic in it. It works pretty well on other parts of the exhaust like the heat shield and header(I will be boosting soon though ) And it looks pretty good so long as you do an even coat at applying it.
Old Jan 18, 2006 | 08:35 AM
rioninja's Avatar
Default Re: High-Temp flat black manifold paint? (broketuner-egb16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by broketuner-egb16a &raquo;</TD></TR><TR><TD CLASS="quote">
I don't know how hot temps get on a turbo mani. but dupli-color has a 1200' F rated spray with ceramic in it. It works pretty well on other parts of the exhaust like the heat shield and header(I will be boosting soon though ) And it looks pretty good so long as you do an even coat at applying it.</TD></TR></TABLE>
Yeah, that stuff works pretty well on exhaust manifolds.. Should be ok for most daily driven setups.
Old Jan 18, 2006 | 08:56 AM
I Have an STD's Avatar
wrenchin'
Default Re: High-Temp flat black manifold paint? (rioninja)
doesnt work. i SANDBLASTED a manifold before i painted it with VHT 2k degree paint. how much better prep can u get than that?? wiped it down with alcohol, painted it, 2 days later, no more paint. face it, if a mani looks like crap, its gonna look worse with paint on it
Brett
Old Jan 18, 2006 | 09:06 AM
fjt's Avatar
fjt
Wrap the manifold, then ceramic/spray coat it with VHT 2000 degree paint..
I did it to my Downpipe and it has worked really good.
Old Jan 18, 2006 | 10:49 AM
Wilky's Avatar
Default Re: (fjt)
Doesn't wrap cause whatever metal it surrounds to retain moisture? = bad for daily driver. Would spraying it afterward help with this?
Old Jan 18, 2006 | 11:12 AM
Default Re: (Wilky)
I hate cars, bump
Old Jan 18, 2006 | 11:19 AM
nerdsports's Avatar
Default Re: (boostincoupe)
i painted my short tubular manifold w/ black high-heat paint (1200*F).
that was like 3 months ago, its still black and no chips.
Old Jan 18, 2006 | 11:20 AM
Default Re: (nerdsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nerdsports &raquo;</TD></TR><TR><TD CLASS="quote">i painted my short tubular manifold w/ black high-heat paint (1200*F).
that was like 3 months ago, its still black and no chips. </TD></TR></TABLE>
PICS or ban FTW!!
Old Jan 18, 2006 | 11:30 AM
SL0WEGG's Avatar
speak to chuck from boostfactory, he knows someone locally that does coating, pretty cheap if i remember correctly
Old Jan 18, 2006 | 11:35 AM
Default Re: (boostedej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedej1 &raquo;</TD></TR><TR><TD CLASS="quote">speak to chuck from boostfactory, he knows someone locally that does coating, pretty cheap if i remember correctly</TD></TR></TABLE>
you rock!!! I'll hit him up once I get the manifold.
Old Jan 18, 2006 | 11:51 AM
bigdaddyvtec's Avatar
* B A N N E D *
Glass beaded my SS mani, cleaned it with air, then acetone, then blew it with air again... heated it in the oven for a few.. and sprayed the **** out of it with the VHT Flameproof Exhaust paint...the ceramic **** (brushed aluminum color). Looks great, I BEAT BEAT BEAT this car and it still looks great at a month or so out....
My 2
Pennies.....
Spike
Old Jan 18, 2006 | 11:55 AM
yellowturbo's Avatar
I would like to paint my turbo housing to keep it free from rust. I hope that the 2000F VHT paint will work...
Damn I just remember that it painted my Greedy manifold a while back and it was holding fine. I think that that paint hold really well on the cast material... not on the steel and stainless steel...
Old Jan 18, 2006 | 11:58 AM
Default Re: (yellowturbo)
not really close to the manifold but you can see that its clean... damn I was ricer with my clear corner lol !!! this is from like 5 years ago.
Old Jan 18, 2006 | 12:02 PM
chitownrida's Avatar
i'm using the vht too, it says only thin even coats if you want it to last.. also heat cycle it.. let it warm and cool a few times before you drive it for long periods
Old Jan 18, 2006 | 12:03 PM
Default Re: (chitownrida)
Will you people post pics of your painted manifolds already??!?
