high milage motor boosted
Old Mar 31, 2013 | 09:29 AM
jdmb18b1flip's Avatar
Default high milage motor boosted
hey ppl i got a ????i have a 91 d.a with stock everything the engine has 271,xxx miles but is healthy just gave it a tune up
planing on going ls-v turbo on stock internals
have universal intercooler piping
greddy trype 2 bov
deltagate mark2 wastgate an rump tube
310 cc injectors
waldbro 255 fp
aem fuel regulater
b16 head
godspeed 20g t3 .57mm turbo
ramhorn manifold
arp head studs
arp rude bolts
acl race berings
gsr water pump and oilpump
14lbs of boost with p28 tuned on neptune
let me know ur opinion
Old Mar 31, 2013 | 09:39 AM
hon2984's Avatar
Default Re: high milage motor boosted
a compression test is in order!
i think you will need bigger injectors that that as well.
Old Mar 31, 2013 | 09:47 AM
s what u thinking like 440cc
ill do the compression tyest next weekend
Old Mar 31, 2013 | 09:48 AM
but does that sound like a pritty good set u ive never gone boost b4
Old Mar 31, 2013 | 09:53 AM
hon2984's Avatar
i like precision injectors because you can get them high impedience, meaning you dont need to install a resistor box. i would go bigger than 440cc.
you are also going to need a map sensor, because oem honda map sensors dont read above 11 psi
i would also recommend a good clutch!
Old Mar 31, 2013 | 09:58 AM
justYncredible's Avatar
It's wU to the sOLdiEr!
14lbs = what?
271k on stock rings is kind of high really high
Old Mar 31, 2013 | 10:03 AM
Turbo-LS's Avatar
those delta gates creep, ditch the godspeed turbo and manifold, get a real turbo. a cast log even a cheap one would be better than a cheap tubular ramhorn. Its a lot of miles but if tuned properly it should last a while. you need larger injectors. some dsm 450's would be fine. also dont be conserned with boost pressure aim for a hp goal.
Old Mar 31, 2013 | 10:13 AM
ya iim saving up to get a new one but this is what i got right now this is just my test run build seing how it goes never did turbo builds b4
building a new ls-v in 3 months
with h beam rods , low comprsiion cp pistons forged crant,new everything as for oilpump and alll thats stuff,,
Old Mar 31, 2013 | 10:20 AM
so you dont have the money right now but youre going to do another build in 3 months?
Old Mar 31, 2013 | 10:25 AM
not at this exaact moment not to get a new turbo and manifold
Old Mar 31, 2013 | 10:58 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Did I just read a TXT message? What is a "rude bolt"? I am also curious how you deemed an engine "healthy" by changing $40 in parts? If that is the case I have some ocean front property to sell you.
Old Mar 31, 2013 | 11:33 AM
mafia's Avatar
Keep talking.... Lol
Old Mar 31, 2013 | 11:56 AM
Here we go always a dumb as.person who thinks. They know everything.. my tune ups.dont cost 40 bucks dumb ***. A tune up for me is changing alot.of **** wapter pupm,timing belt,oil and filter, all gaskets, spark plugs and wires,.. gearoil. Ect......
Old Mar 31, 2013 | 11:58 AM
And. I never said.the.motor is healthy ckuz. I.gave it a tune up i said.its healthy and.i gave it a.complete tune up
Old Mar 31, 2013 | 12:05 PM
grumblemarc's Avatar
The Grumpiest
Contradict much? Healthy? Orly? And how do you know that exactly?
Old Mar 31, 2013 | 12:28 PM
Im saying.its healthy ckuz. It.dont burn no oil, doent smoke out.of the exhaust doesent leak any type.of.water ,idles smooth , starts up. Good, dont over heat, there is.no water.in the oil. No ticking.or.knocking sounds. Doesent shoot any ckods. Or.nothing like that
Old Mar 31, 2013 | 12:30 PM
The Grumpiest
'Cause you say so? Lemme tell you, even engines with **** compression don't exhibit any of the signs you mentioned. Get up off your *** and at least do a compression test.
Old Mar 31, 2013 | 12:46 PM
If u read the.coments.from earlier i was ganna do a compression test on it. Bit i have to buy a compression tester dumb ***. Learn to read othe.post b4 u start trying to school me on this ****. Me.and.other dude.already talked about it.
And.if a car has fucked up compression it will show soghns. That i mentipned it wont start right.up it will strugle to start and stay at idle. Ckuz compression is fucked.up.
Old Mar 31, 2013 | 12:55 PM
The Grumpiest
I read that dumbass. So how about do the damn test and stop posting until you do. And you can rent one. **** you could have done the friggin' test by now.
Next time don't come in here asking for opinions and then catch an attitude with everyone that gives you one because you don't like the message or the way it's being given.
And this?
is bullshit. How many people have I seen over the years saying their cars run strong and they have no issues with them but they do a compression test and the cylinders come back with 90psi across all four. So yeah, I know WTF I'm talking about. So if you think your engine is healthy then why do you even need to do a compression test?
Ckuz?
Old Mar 31, 2013 | 01:06 PM
rich7777's Avatar
How the f**k can he call anyone stupid when he doesn't even know how to use a keyboard. This txt message crap is driving me crazy. What a nightmare.....
Old Mar 31, 2013 | 01:27 PM
no dumb *** there is a diffrence between ppl giving ther apinion and ppl talking down to ppl acting like they no everything so learn the diffrance stupid ****
Old Mar 31, 2013 | 01:29 PM
The Grumpiest
Juvenile high school drop out. If you just shut up and can the attitude you'd get a lot further and have more people willing to help you. Good luck with your future grenade.
Old Mar 31, 2013 | 04:10 PM
DO IT ON ALL FOURS
My dear child, the problem is I DO know it all. You asked for opinions and you got them; now you are crying worse than my grandkids. A compression test only tells you a third of the story. You need to do a leak down test and vacuum gauge/spark plug analysis before any statements are made. Think as you will, but we can only go off of what is given, and what you have provided is pure ignorance.
Anyways, so about that ocean front property, it is down in Arizona. If you buy that I'll throw in the Golden Gate for free.
Old Mar 31, 2013 | 04:29 PM
hon2984's Avatar
wow this thread went down hill quick! honestly OP ther is a few very knowledgable people already posting in this thread.....with honda-tech half of the battle is getting views. you actually have people posting to help you....making comments like that wont get you any further to your goal!
Old Mar 31, 2013 | 04:46 PM
Hidenplanvew's Avatar
You can tell he went to public school in Cali, or he has seizure's while he types.
