high or low compression for turbo
Old Mar 4, 2003 | 07:50 AM
GRTechnologies's Avatar
Default high or low compression for turbo
This is for all you engine builders.
Lets here what compression everyone thinks is better.
And if you were building a motor for yourself what compression would it be?
And why?
Old Mar 4, 2003 | 08:01 AM
BoM's Avatar
BoM
Default Re: high or low compression for turbo (GR)
low compression for better reliability on pump gas.
higher compression for a racecar (more power) on race gas.
im getting a 2.0L block built with 9:1 compression. gonna try to run 30lbs.
Old Mar 4, 2003 | 08:10 AM
CRX SiR T's Avatar
Default Re: high or low compression for turbo (BoM)
both can be very drivable and used as a daily driver.
low --> easier to tune, allows biggest margin for error (thats why many street tuners choose low compression)
high --> quicker spool, more power w/ less boost, harder to tune, small margin for error
if high compression is built and tuned right, it will be signifigantly better than low compression
Old Mar 4, 2003 | 08:28 AM
should make power @ 30 psi.
Old Mar 4, 2003 | 08:29 AM
Default Re: high or low compression for turbo (CRX SiR T)
cool
Old Mar 4, 2003 | 09:07 AM
alpha's Avatar
My B16a block is at GEM right now. I'm using 9.2:1 pistons.
Old Mar 4, 2003 | 09:15 AM
Flamenco-T's Avatar
Default Re: high or low compression for turbo (0x64)
b18C1, Wiseco 9.8:1...with 60-1, I can't imagine being on 8.5 or 9.0:1 CR
Old Mar 4, 2003 | 09:20 AM
alpha's Avatar
Default Re: high or low compression for turbo (Flamenco-T)
When I get my overbored Honda head gasket it should bump compression up a little bit.
Old Mar 4, 2003 | 11:32 AM
Diego Boost's Avatar
I agree with everyone here so far.
Old Mar 4, 2003 | 11:39 AM
b18bturbo's Avatar
Default Re: high or low compression for turbo (Diego Boost)
mixture of compression is good a little high and little low. I like stans idea 9.8:1 its the way of the future
Old Mar 4, 2003 | 11:50 AM
PM-Performance's Avatar
Default Re: high or low compression for turbo (b18bturbo)
high compression feesl great in and out of boost and dont need alot of boost to get great powr.
but tuning can be a bitch sometimes.
have a really good tuner and good management if you go high cvompression beucase it isnt as forgiving as said above.
Old Mar 4, 2003 | 06:29 PM
xonn's Avatar
Default Re: high or low compression for turbo (itr206)
My current compression is 11.2:1 and I'm considering add a supercharger... I'm running a custom grind from with lots of duration so the dynamic compression of the engine really isn't that high. My goal is to run 7 psi on top of what I currently have. In GA, 93 octane is plentiful and is currently all I run in the engine. Comments?
Old Mar 4, 2003 | 07:06 PM
Danger's Avatar
Default Re: high or low compression for turbo (xonn)
i went ROSS 10:0 compression pistons for my built b18c5 . i havent decided what turbo to use yet . i have a standard t3t4 left over from my old car but i dont think it would make enough power for the times im looking for .
Old Mar 4, 2003 | 07:54 PM
Pelican's Avatar
Default Re: high or low compression for turbo (JonnyDanger)
<9:1 is too low
>12:1 is too high
IMHO
Old Mar 4, 2003 | 07:57 PM
sharkcohen's Avatar
Running a large amount of duration for high compression on an NA engine is fairly standard. Running high duration on a boosted engine is a no no, unless you like blowing your boost pressure out your exhaust valves.
[Modified by sharkcohen, 4:57 AM 3/5/2003]
Old Mar 4, 2003 | 08:07 PM
import palace's Avatar
i personally prefer a higher cr for turbo apps. cause you eliminate a bit of the turbo lag and you produce more power in the long run. yes there is a finer line as far as errors in tuning are concerned but a standalone can eliminate alot of those issues.
Old Mar 4, 2003 | 08:13 PM
MiraiZ's Avatar
Default Re: high or low compression for turbo (import palace perf)
9:1 is clean (LOL)
Old Mar 4, 2003 | 08:17 PM
xonn's Avatar
Default Re: high or low compression for turbo (MiraiZ)
So basically it's an inefficient way to make more power... I'd be loosing more boost than it would be worth..
Old Mar 4, 2003 | 08:18 PM
MotorMatrix.com's Avatar
I am a bad person
I like lower compression and a ton of boost. Lag is your friend on the street. I'm staying 9:1 on my new setup and stock bore basically .020 over. GR on the other hand is going 10.5:1 on some alky. Sick Bastard!!!
I see your trying to get rid of the trial user status huh?? 17 posts Big dog!!!
[Modified by MotorMatrix.com, 1:00 AM 3/5/2003]
Old Mar 4, 2003 | 08:27 PM
DIRep972's Avatar
Smarter than you
low compression
- more timing
- more boost
- more lag
- less efficient hp
- more room for error
high compression
-less timing
-less boost
-quicker spool
-more efficient power
- requires more precise tuning
Id like somewhere inbetween.
Old Mar 4, 2003 | 08:36 PM
rOby's Avatar
Default Re: high or low compression for turbo (DIRep)
10:1 here
Old Mar 4, 2003 | 08:44 PM
boosted hybrid's Avatar
Default Re: high or low compression for turbo (rOby)
8.8~9:1 here. I prefer 9:1 compression, even after having 11:1 for awhile. You can still make very good power with 9:1 compression. My goal is 400whp on pump gas with my compression and engine/turbo kit. Its very realistic, and adds a little safety blanket for tuning and overall reliability.
Old Mar 4, 2003 | 09:49 PM
highbrid's Avatar
Default Re: high or low compression for turbo (boosted hybrid)
me = 10.4:1 cr
Old Mar 4, 2003 | 11:37 PM
pissedoffsol's Avatar
Default Re: high or low compression for turbo (highbrid)
im running (or will be rather) 9.1 pistons in a gsr with a b16 head, so that drops me to lik 8.8. I, like motormatrix, like the idea of lag in a street car. I also think that high compression is for N/A guys. We have turbo's to make up the rest of our effective compression
Old Mar 5, 2003 | 12:51 AM
darkracer's Avatar
Default Re: high or low compression for turbo (delvtecsol)
low, how low can ya go.... i would run about the stock 9.1:1 cr or 9:1 around 9:1 sounds nice to me.
