HF Manifold?
Just wondering if anyone can confirm the manifold in this link is actually an HF style manifold I could use with an adapter plate for a D16 turbo setup. I just question it a bit because it seems to look a bit different than the common HF manifold pictures I've seen, so are there two slightly different styles?
http://cgi.ebay.ca/ws/eBayISAPI.dll?...L:COSI:CA:1123
no thats the wrong one . If i remember correctly the cars the manifold was on is 88-91 crx HF, 88-91 civic STD, 92-95 civic Cx and Vx
Can anyone else confirm this? I've already agreed to buy it, but they have a return policy and I haven't paid yet, so if it's wrong I'll just try to work out something with them to save all the time and hassle of shipping and returning. What is this manifold then if it's not an HF manifold like they say? The bolt holes at the collector look almost like the HF, but the manifold does look a bit different overall.
yes its a y7 pre cat mani, where the cat bolts right to it rather than under the car...as stated ^ unless u can do work
in a shop, look for the actual one which comes on the ^ stated models
-go here, i called this guy before, $40 shipped bro check it out
http://cleveland.craigslist.org/pts/1610919680.html
The one you want looks like this:
There are three versions of the hf manifold people use for adapter plate setups. The hf, std, and cx... I'm fairly certain the hf has an L cast into it, the std has a 3, and I don't remember what the cx one's identifying feature was...
My HF has an L on the left of it. I wanted to paint ours with hi-temp paint; good to 2000 degrees. Kinda goes with the "theme" of the bay/car.
BTW; it's still wet that was after 2nd coat of paint.
there's actually 4 your forgot to mention the Vx manifold which is what i used ages ago. oh something else that hasn't been mentioned here and according to the H M T FAQ for the HF manifold the "std" manifold has the largest runners out of the 4
