Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   HELPPPPPPPPPP!!!! (https://honda-tech.com/forums/forced-induction-16/helpppppppppp-1183157/)
TA Performance Mar 17, 2005 07:10 PM
HELPPPPPPPPPP!!!!
i need some help from you turbo guys...
my vacuum is at 8 instead of 20 and my bov wont blow off till HARD acceleration... and it wont boost till like 6k rpm.. i feel something is wrong and in eed your guys help. checked vacuum lines and charge pipes seems fine but i dont get it
TIA
93turbo16 Mar 17, 2005 07:22 PM
more than likely is a charge pipe and a vacuum line it seems. The gauge should be reading 20, that suggests a vacuum line, and also since you aren't building boost, that kinda means charge pipe. Not sure what else to suggest.
TA Performance Mar 17, 2005 07:38 PM
would it be ok to drive around like ethat? or do i have to fix that problem asap???
PrettyLude Mar 17, 2005 09:34 PM
i would try and fix it asap, you can possibly overspin the turbo
SSBPGSR Mar 17, 2005 09:53 PM
Re: (PrettyLude)
does your idle surge? if its reading such a low vacuum pressure i would assume theres a noticable leak. check all the T's and connections, and the fitting that goes into the boost guage. and if you cant build boost, i cant think of anything aside from a coupler being lose, or some tiny pinholes in the welds.
TA Performance Mar 17, 2005 10:04 PM
Re: (SSBPGSR)
thanks guys ill check up on the connectors... but as far as the t fittings and vacuums i checked them all they look good to me
SSBPGSR Mar 17, 2005 10:17 PM
Re: (Boro_DC2)
your BOV should have its own vacuum source, BOV and wastegate should always have there own source, ( if the WG isnt hooked up to the compressor housing )
TA Performance Mar 17, 2005 10:36 PM
naw my wastegate is hooked up the intake manifold and so is the bov... also the wierd thing is that before my type s sounds sharp, kinda laser like sound but now it has this wooooooooosh with a echo... would having a loose chargepipe of vacuum leak cause the bov to sound like that
SSBPGSR Mar 18, 2005 07:39 AM
Re: (Boro_DC2)
i used to have a type S bov, and when i would let off the gas it would have the same swoosh sound unless i was boosting over 6psi. every bov will sound diff on diff peoples cars, why? i dont know..but its something i have noticed. just check over all the connection, check the back of the boost guage..thats one place people always forget to look
TA Performance Mar 18, 2005 09:57 AM
Re: (SSBPGSR)
thanks https://honda-tech.com/forums/images/smilies/emthup.gif
