Help wiring aem sensors..
Old Jan 27, 2006 | 09:40 PM
adictionbass's Avatar
Default Help wiring aem sensors..
Everything is finished. Thanks for the help guys
first off, thanks for any help in advance.
#1 answered - Thanks EE_Chris
second is an EGT sensor. There is one grey wire and one white wire. which one goes where?
I am not running a stock O2 sensor and will be using a uego gauge type A/F gauge. I was told to hook the Uego output into the ecu at the O2#2 wire. What wire is that? (what pin number)??
thanks again for any help
Modified by adictionbass at 12:31 PM 1/30/2006
Modified by adictionbass at 7:00 PM 1/30/2006
Old Jan 27, 2006 | 11:11 PM
Default Re: Help wiring aem sensors.. (adictionbass)
up for the night/morning
Old Jan 28, 2006 | 09:08 AM
Old Jan 28, 2006 | 09:35 AM
.dave's Avatar
i HAS questions ?
If you want to use O2 feedback to adjust fuel you have to run it to O2#1.
I forgot how I have my IAT hooked up but I'll take a look when I go home today/tomorrow and let you know.
Old Jan 28, 2006 | 09:44 AM
Default Re: Help wiring aem sensors.. (daveG)
thanks for the info. ive got a helms out and it labels the wires
_
AB (sensor side)
CD
and i cant figure out what pins O2#1 and/or O2#2 is on the ecu.
Old Jan 28, 2006 | 06:38 PM
maybe ill get more help on a week day...
Old Jan 28, 2006 | 10:33 PM
.dave's Avatar
i HAS questions ?
The AEM manual should label the O2#1 sensor.
Old Jan 28, 2006 | 10:34 PM
well, i wish i had a manual
.dave's Avatar
i HAS questions ?
I'll be at my house/around my car tomorrow. I'll check it out and let you know where I wired things.
Old Jan 28, 2006 | 10:39 PM
thanks for the help man
Old Jan 29, 2006 | 11:02 AM
sunday
Old Jan 29, 2006 | 02:07 PM
Ok, so i guess ill try to help you help me.
The IAT wires to what the helms lables and Green/White2 and the red/yellow. THe green/white 2 wire also supplies the O2 sensor and coolant temp sensor. I tapped into the green/white wire2 and the red/yellow wire for the IAT here:
This is the plug for the IAT, it is labeled A and B. I need to know which wire goes to which.
This is the pig tail for the EGT.:
Im assuming i can use the the green/white2 wire lead where the O2 sensor pluged in that also runs for the IAT and coolant temp sensor. Would this green/white2 wire need to go to the white or grey wire on the egt pigtail? Planning on using the orange/blk wire for the other egt wire to run back to the ecu.
I also still need to know where to plug the uego signal wire into the ecu...
thanks for looking and any help guys...
Old Jan 30, 2006 | 07:48 AM
monday bump
Old Jan 30, 2006 | 08:39 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daveG &raquo;</TD></TR><TR><TD CLASS="quote">The AEM manual should label the O2#1 sensor.</TD></TR></TABLE>
I broke out the ETM and the stock O2 sensor is as follows:
1 (white wire) O2sensor input (pin D 14)
2 (green/white) sensor ground (D22)
3 (yel/BLK) runs to the fuel injector wiring???
4 ( Orange/blk) Heater control (A6)
assuming the uego goes to D14?
IntegraType-R
Sep 29, 2008 05:40 PM
lurken
Oct 16, 2006 02:28 PM
allicedout
Jun 20, 2004 06:56 AM
HyperFlow
May 23, 2003 09:17 PM
