help on turbo for 400hp
Old Oct 30, 2008 | 09:29 AM
hawkturbo's Avatar
Default help on turbo for 400hp
ok i got the gt32 garrett turbo i wana now if this turbo is good for make 450 or 400hp
is in ls/vtec whit forget internals thanks
Old Oct 30, 2008 | 09:47 AM
spoolin turbo s's Avatar
Default Re: help on turbo for 400hp (hawkturbo)
i don't think it'll make 400whp
does it have a divided turbine?
pm theshodan and he could probably take that turbo and maybe switch one side or the other and make a turbo capable of about whatever you want and it would probably be cheaper than buying a new turbo
it olso depends on which gt32 it is there are 3 variants of it
Old Oct 30, 2008 | 11:41 AM
GT35R_EF's Avatar
Make mine whatever you want
Yea, it should make that power. What back housing is on it?
Old Oct 30, 2008 | 06:40 PM
hawkturbo's Avatar
ok the cold zs is 49 and hot zs is 69
Old Oct 31, 2008 | 10:59 AM
hawkturbo's Avatar
Help
Old Oct 31, 2008 | 11:03 AM
LA_HONDAS's Avatar
Default Re: (hawkturbo)
http://turbobygarrett.com
Old Oct 31, 2008 | 12:04 PM
Schister66's Avatar
Man U FTW
The turbo flows enough air to make 400-450whp, but your fuel grade will be the limiting factor. You can make 400whp on pump gas with that turbo, but any more would be pushing it
Old Oct 31, 2008 | 12:26 PM
TheShodan's Avatar
Moderator
Default Re: (Schister66)
Looks to me as though he has the smaller 71mm unit. That would be good to about 350whp or so. 400whp is really stretching it. If it were for an LS, it is perfect. If it is, it is perfect.
Old Nov 1, 2008 | 06:19 AM
hawkturbo's Avatar
ok this is mi setup
Head p78
ITR spring y retainers
ITR cams
Aerospeed cam gear
BBK 70mm TB
IM Victor X
PTE 880cc
AEM Fuel Rail
FPR Aeromotive A1000
Hondata IM gasket
Block B18A
stock slevees 81.5mm
Manley Pistons and rod 9:1
Moroso crank
Golden eagle Vtec kit
fluidamp
drag Manifold
tial 38wg
bov tial 50mm
and gt32
wanna hit 450 on race gas
stknfghtr1
Aug 3, 2011 10:52 PM
stknfghtr1
Aug 3, 2011 06:21 PM
Scotty Dosent Know
Aug 2, 2006 05:04 PM
