help with return line. it's short, no 56k. >>
Old Jan 30, 2005 | 06:52 PM
platinum00's Avatar
Default help with return line. it's short, no 56k. >>
ok, this return line is so short, i dont really know how to run this.
any ideas.
sorry for the big picks. how do you resize?
more pics of the return line can be found here.
http://pwtuning.com/project_ca...nline/
thanks
platinum.
Old Jan 30, 2005 | 06:55 PM
HamiltonRex's Avatar
Default Re: help with return line. it's short, no 56k. >> (platinum00)
punch the pan, put in a 45" run a straigh piece. Anyone see a problem with this?
Old Jan 30, 2005 | 06:58 PM
DefiantGSR's Avatar
Don't run a 45 degree off of the turbo. It'll swoop down into the oil pan..
Old Jan 30, 2005 | 07:02 PM
platinum00's Avatar
Default Re: help with return line. it's short, no 56k. >> (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">punch the pan, put in a 45" run a straigh piece. Anyone see a problem with this?</TD></TR></TABLE>
what do you mean by punch the pan..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Don't run a 45 degree off of the turbo. It'll swoop down into the oil pan..
so just a run a straight peace down, not the 45, and then hook my 10an fitting to that.
Old Jan 30, 2005 | 07:04 PM
beepy's Avatar
I would just use straight and 45° 1/2" hose barbs. There is no reason to use aeronautical lines in such a low pressure application. The rubber hose would make a gentle arc towards the pan, and the I.D. is larger than -AN.
Old Jan 30, 2005 | 07:26 PM
platinum00's Avatar
Default Re: help with return line. it's short, no 56k. >> (beepy)
so dont use steel braided at all. just the fittings and rubber hose.
what about heat on that exposed rubber.
platinum.
Old Jan 30, 2005 | 07:50 PM
DefiantGSR's Avatar
https://honda-tech.com/zerothread?id=1011921
Get a rubber hose like this one..Ask Stan(flamenco-T) if he'll hook you up with some. It'll be fine as long as it doesn't touch anything hot..
Old Jan 30, 2005 | 07:56 PM
m R g S r's Avatar
My return sucks cuz of this very problem. . . .
I have to redo it with soft rubber hose in the future. . .
Old Jan 30, 2005 | 08:51 PM
platinum00's Avatar
Default Re: help with return line. it's short, no 56k. >> (m R g S r)
rubber hose it is then.
so it being real short wont hurt anything as long as the flow is good going into the pan.
is the place that i have my pan tapped good. I dont want to blow any seals on this new turbo.
platinum.
Old Jan 30, 2005 | 08:53 PM
adseguy's Avatar
Default Re: help with return line. it's short, no 56k. >> (DefiantGSR)
I had the same problem Platinum an di just ditched the steel braided hose and went to Lowes and got some rubber tubing. I used the same 45 degree and just clamped it on. no leaks...no problems....just make sure it doesn't pinch anywhere
Old Jan 30, 2005 | 08:56 PM
platinum00's Avatar
Default Re: help with return line. it's short, no 56k. >> (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">just make sure it doesn't pinch anywhere</TD></TR></TABLE>
yea that's what im worried about under high heat. Is there special rubber hose i can get that winstands heat a little better, so maybe it wont pinch or colapase?
platinum.
Old Jan 30, 2005 | 09:04 PM
eg6T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">My return sucks cuz of this very problem. . . .
man,you are rollin loowww
Old Jan 30, 2005 | 11:28 PM
racinskittle's Avatar
Default Re: help with return line. it's short, no 56k. >> (eg6T)
straight piece off of the turbo or the oil pan. OTHERWISE there's another option....i gotta see if i can find pics. I found the SS return line in an AVO turbo kit for my friends subaru legacy. It's an SS return with the anodized ends (like usual) but instead of the screws, the hand clamps on the end. (there were holes cut in the metal to fit the screw part of the clamp). They were ******* genious. I wish i had pics
Modified by racinskittle at 8:41 AM 1/31/2005
Old Jan 31, 2005 | 04:03 AM
btotherizzle's Avatar
I have been running a heavy duty 350 psi rubber hose for 4 years now with no melting or problems whatsoever. The hose sits 1'' from my downpipe.
Old Jan 31, 2005 | 04:33 AM
platinum00's Avatar
Default Re: (btotherizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by btotherizzle &raquo;</TD></TR><TR><TD CLASS="quote">I have been running a heavy duty 350 psi rubber hose for 4 years now with no melting or problems whatsoever. The hose sits 1'' from my downpipe.</TD></TR></TABLE>
where can i get this hose at.
platinum.
Old Jan 31, 2005 | 06:11 AM
Hyaboosta's Avatar
Default Re: (platinum00)
I had the same problem with mine but I saw it before I tapped the pan so I just taped in a barb fitting and put the hose right on it so I didn;t have the adaptor on the end of the fitting taking up all that space.
Old Jan 31, 2005 | 06:38 AM
Slammd Sol's Avatar
I'd go with a rubber hose, its what I have been running on my setup for 2 years. Just measure the length and the appropriate bends needed and go to autozone, walk behind the counter to the wall of hoses and find one thats the right diameter with the right length/bends.
Old Jan 31, 2005 | 07:19 AM
EJ1 wilcox's Avatar
Default Re: (Slammd Sol)
You are going to want to find high-temp, high-pressure hose... I think the stuff that Flamenco-T sells in his return line kits is just fuel line...
Any auto parts store should carry it...
Old Jan 31, 2005 | 12:30 PM
platinum00's Avatar
Default Re: (EJ1 wilcox)
well i just picked up the hose and fittings. went to a couple places and they only had high temp 10an fuel line. im assuming this will work. will it not ?
also jegs did not have a bulkhead 45 barb fitting. so i got my bulkhead straight to a 45, hopefully it will work.
i will put everything on and take some pics and post up in a couple of hours.
platinum.
Old Jan 31, 2005 | 01:35 PM
Kwuaymaikrup's Avatar
That is long compared to mine. You shouldn't have a problem.
-Ryan
Old Jan 31, 2005 | 01:43 PM
platinum00's Avatar
Default Re: (Kwuaymaikrup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwuaymaikrup &raquo;</TD></TR><TR><TD CLASS="quote">That is long compared to mine. You shouldn't have a problem.
-Ryan</TD></TR></TABLE>
crazy, do you have a pic of that.
platinum.
Old Jan 31, 2005 | 01:54 PM
platinum00's Avatar
ok here we go. i moved the turbo in just a bit to make it work.
i think it looks fine, but let me know. also check out the clearance now with the A/C / Mount bracket. little close i think
Clearance Problem maybe..
platinum.
Old Jan 31, 2005 | 02:05 PM
EJ1 wilcox's Avatar
Looks like you are in business
I don't think you could get it any better...
Old Jan 31, 2005 | 02:13 PM
platinum00's Avatar
what about the clearance with the bracket?
platinum.
Old Jan 31, 2005 | 02:17 PM
darkdayz's Avatar
you did it good job
