Help with reading plugs
Old Dec 18, 2011 | 01:28 PM
rrd5011's Avatar
Default Help with reading plugs
440WHP @19psi. B16 (9.1 compression). Timing is 19 degrees. NGK V power heat range 9's gapped to .028. These plugs have only seen dyno time and about 100 miles on the street. I pulled them on cold engine. Can someone help me with the proper steps of how to "read plugs". Should I use NGK 8 heat range with same gap??
Pics are from cylinder 1 and 3
Thanks
Old Dec 18, 2011 | 02:30 PM
C2K_TB_TEC's Avatar
Default Re: Help with reading plugs
Need better pics of the ground strap, to check ign timing.. Seems like mixed driving timing marks. Do wot pulls and shut the car down to get a better idea of plug range, timing and a/f.. But from what I can see it looks ok, idle is a bit on the rich side, or plug might be cold at idle. Pics showing the base ring at the bottom of the ceramic, is needed also.
Old Dec 18, 2011 | 04:20 PM
Thomascivicsi's Avatar
Better pics so we can give better info...
Old Dec 18, 2011 | 04:35 PM
rrd5011's Avatar
Thanks for the help guys. I will get some better pics. So you need a close up of grounding strap and a close up of ceramic ring at base. Just to be straight, I do a couple WOT pulls and then literally shut off coast and pull plugs??
Old Dec 18, 2011 | 05:43 PM
GEN2 LS's Avatar
Loved
yep, a few pulls, then just literally shut it off, and pull the plugs.
Old Dec 18, 2011 | 08:42 PM
chancek's Avatar
This might be some help on plug readings
http://www.4secondsflat.com/Spark_plug_reading.html
Old Dec 19, 2011 | 03:43 PM
boostedb18ccoup's Avatar
looks good with a bit of carbon or oil build up. probably just carbon
96 GSR-T
Jun 24, 2006 05:09 AM
onlyneed4
Apr 23, 2005 12:08 PM
Yyz
Apr 6, 2005 01:11 PM
DLB1994
Feb 7, 2002 07:24 PM
