help me pick a trans setup, also input on Prodrive spool
Old Sep 11, 2002 | 10:40 AM
boosted3g's Avatar
Default help me pick a trans setup, also input on Prodrive spool
Here are my options that i have. I can have either a LS trans with a quaiffe or a GSR trans with a prodrive spool. I would like to run the car on the street very occasionally so i have a few questions hopefully you guys with experience can help me out.
1. can you turn at all with a spool or does it just turn like ****
2. to anyone with 24.5 inch slicks, how much mph can you get out of the GSR trans at around 8500 rpm or what is your speed and revs when going through the traps.
Old Sep 11, 2002 | 10:56 AM
93LSivic's Avatar
Default Re: help me pick a trans setup, also input on Prodrive spool (boosted3g)
Dont get the Prodrive. Im sure Viren and Art can tell you more on this.
Go with Damon's....Im assuming its his tranny your looking at.
EDIT* I installed valve springs in my LS the other weekend and was finally able to rev higher. I took it to 8000 in 4th gear (stock GSR tranny) and the speedo said 120mph----this was on my street tires with a rough diameter of 23 inches. Im sure with the 24.5" slicks and your new setup you should be able to go through the traps in 4th with your higher speed and redline.
[Modified by 93LSivic, 3:06 PM 9/11/2002]
Old Sep 11, 2002 | 11:06 AM
b18bturbo's Avatar
when i used to run 24.5 inch with GSR trans and quaife traps would be around 135-140 so you can easily get it dont. With ls trans i was turning 132-135 mph traps the GSR netted faster mph and better acceleration in my opinion. The spools from prodrive work but nto really worth it.
boosted3g's Avatar
Default Re: help me pick a trans setup, also input on Prodrive spool (93LSivic)
Nope i alredy have the LS with the Quaiffe in it. Im going through the traps at 129 at around 8000. My buddy needs an LS trans and wants mine and he is willing to buy me a GSR trans and a Prodrive for it if i decide to trade. After seeing Prodrive on the products that dont work post in edgy. I plan on putting down over 500whp and the last thing i want is a busted dif. Im not sure if ill run out of gear with the GSR tranny either.
Old Sep 11, 2002 | 11:13 AM
boosted3g's Avatar
Viren, so the prodrive doesnt net anymore traction or its not gonna hold up. Or is it jsut too much for what you get out of it. Im thinking about making the car a true race car so using a spool and not being able to drive it on the street is not one of my main concerns, i jsut want to go fast. i have other cars if i need to go anywhere
Old Sep 11, 2002 | 11:25 AM
b18bturbo's Avatar
i would stick with quaife the spools work but they also put alot of stress on the trannies;
Old Sep 11, 2002 | 07:02 PM
earl's Avatar
Default Re: help me pick a trans setup, also input on Prodrive spool (b18bturbo)
I feel the spool puts more stress on the axles, also.
a1320honda
Oct 10, 2013 07:59 AM
95eggsr66
Dec 2, 2012 07:23 PM
ykracing
Dec 2, 2006 10:25 AM
getnasty
Feb 2, 2005 12:59 PM
boosted3g
Oct 1, 2002 12:52 PM
