Here's my situation: I can start the car but as soon as it goes into gear it's like all fuel is cut-off and it bogs and dies... well sort of if i let go off the gas and back to neutral it bogs and goes back to idling normally...
So far i checked the ignition because there seem to come a noise from inside the distributor but it looks fine all the gear teeth are there nothing seems broken...
Thanks in advance...
David
Set-up:
Rev Hard II
310s
FMU (don't know the ratio)
FPR
Missing Link
AVC-R
David
Set-up:
Rev Hard II
310s
FPR
Missing Link
AVC-R
is it a 5 speed or auto
is this a new problem or after you installed the 310's with the fmu
[Modified by CovertFI, 7:37 PM 5/6/2002]
TTT
I've had this for about a year or so... But still can't figure out what is wrong...
Any help would be appreciated
David
David
