Help with Endyn breather kit install
Old Apr 6, 2007 | 12:44 PM
Boosted_Coupe's Avatar
Default Help with Endyn breather kit install
Hey guy's i'm in the process of installing my endyn breather kit, and i'm not sure witch way i need to install the freezer plug. Can someone let me know which way is the correct way?
Like this, #1
Or like this, #2
Old Apr 6, 2007 | 12:46 PM
BoostedEG6's Avatar
Default Re: Help with Endyn breather kit install (SiR_JDM95)
Old Apr 6, 2007 | 12:50 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Help with Endyn breather kit install (BoostedEG6)
general "name rank and serial number"
donald sutherland "NUMBER 2 SIR!"
dirty dozen.......
he hee it is #2 as stated above.
Old Apr 6, 2007 | 01:05 PM
Default Re: Help with Endyn breather kit install (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">general "name rank and serial number"
dirty dozen.......
he hee it is #2 as stated above.</TD></TR></TABLE>
What?? lol
Thanks guys
Old Apr 6, 2007 | 01:27 PM
RCautoworks's Avatar
#2 , but it looks like its not in all the way, just making sure you know it goes in more
Old Apr 6, 2007 | 02:38 PM
eddie_ek's Avatar
Always #2 and put it in a little deeper, LOL
Old Apr 6, 2007 | 03:27 PM
Default Re: Help with Endyn breather kit install (eddie_ek)
I was just holding it there with my finger. It wasn't in pushed in at all.
Sounds kinda dirty..
Thanks guys.
Old May 21, 2007 | 08:02 PM
thelate1's Avatar
Default Re: Help with Endyn breather kit install (Boosted_Coupe)
also, when running the endyn kit, can you remove the charcoal canister as well as the pods beside the map sensor? i thought the charcoal canister has to do with the stock "black box" mounted to the block.
clearify please, thanx.
Old May 21, 2007 | 09:06 PM
Sprockets's Avatar
dirty dozen.......
Great movie!
Old May 21, 2007 | 09:31 PM
Timmay's Avatar
Default Re: Help with Endyn breather kit install (Sprockets)
i put mine in like #1
hionvtecxda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eddie_ek &raquo;</TD></TR><TR><TD CLASS="quote">Always #2 and put it in a little deeper, LOL </TD></TR></TABLE>
thats what she said
Old May 22, 2007 | 05:08 AM
ladysman's Avatar
Yes, #2.
Old May 22, 2007 | 05:11 AM
SOHFAST94's Avatar
Default Re: Help with Endyn breather kit install (ladysman)
You guys are hilarious.
#2 by the way. lol.
Old May 22, 2007 | 07:23 AM
Timmay's Avatar
just curious is there any reasoning behind doing it the 2nd way?
Old May 22, 2007 | 01:33 PM
thelate1's Avatar
Default Re: Help with Endyn breather kit install (thelate1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thelate1 &raquo;</TD></TR><TR><TD CLASS="quote">also, when running the endyn kit, can you remove the charcoal canister as well as the pods beside the map sensor? i thought the charcoal canister has to do with the stock "black box" mounted to the block.
clearify please, thanx.</TD></TR></TABLE>
anyone???
Old May 22, 2007 | 05:35 PM
boostek9's Avatar
if you dont know how to install a freeze plug, then i do not recommend building anything yourself
just a cautious warning, not trying to be rude
Old May 25, 2007 | 08:45 AM
cjames235's Avatar
Default Re: Help with Endyn breather kit install (Timmay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay &raquo;</TD></TR><TR><TD CLASS="quote">just curious is there any reasoning behind doing it the 2nd way?</TD></TR></TABLE>
cus thats the correct way
edit: i guess you have never looked at any other engines besides a honda bc most other engines have plugs over the coolant passages.......... and they are all faced like #2
Old May 25, 2007 | 11:51 AM
Timmay's Avatar
Default Re: Help with Endyn breather kit install (cjames235)
so that makes it right?
i put mine in like #1 and it worked ..
I dont think either way is right or wrong
Old May 25, 2007 | 12:08 PM
97gsrki's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay &raquo;</TD></TR><TR><TD CLASS="quote">so that makes it right?
I dont think either way is right or wrong</TD></TR></TABLE>
cummins blocks have several freeze plugs and they go like #2.
Old May 25, 2007 | 02:20 PM
oscarmayer's Avatar
if you don;t do it liek #2 you will soon feel like #2 when your motor goes poo
Old May 25, 2007 | 02:24 PM
Topdawgg's Avatar
where can I get one of these?
I got the 2 fittings from honda for the back of tbe block, just gotta plug the bottom portion
Old May 25, 2007 | 02:36 PM
Timmay's Avatar
Default Re: (Topdawgg)
i got mine at car quest for like 30 cents
Old May 25, 2007 | 03:51 PM
Topdawgg's Avatar
what did you ask for?
Old May 25, 2007 | 05:11 PM
Blackturboteg's Avatar
I just put mine on and two of my other friends have also done the endyn... they all have done it like picutre on and are all ok.. i just put mine in a put mine in like 1... I dont see why you would put it in like number 2 but hey..
Old May 27, 2007 | 01:03 PM
cjb92's Avatar
34.3mm freeze plug
