Help determining compression ratio
Old Dec 10, 2006 | 01:27 PM
CustomX113's Avatar
Banned
Default Help determining compression ratio
i have a je pistons that are suppose to be 9.1:1 or 9.2:1 in an ls, im currently running a ls vtec with a gsr head with a cometic .030 head gasket, i cant seem to find the specs on the piston to punch it into zealautowerks (which i heard wasnt to accurate to begin with) im sure someone on here is running the same setup and know right off hand what it is
Old Dec 10, 2006 | 02:14 PM
abnaasefmb's Avatar
Default Re: Help determining compression ratio (95dxb18c1)
http://www.c-speedracing.com/h...c.php
maybe this will help
Old Dec 10, 2006 | 02:31 PM
SOHC_MShue's Avatar
Calculate the total volume at bdc and divide it by total volume at tdc. If you know the combustion chamber volume in the head, the piston dish or dome volume, the piston to deck height, the bore and stroke size, and headgasket thickness then you can calculate it.
WorrGame13
Mar 30, 2007 03:35 PM
Takumi Fujiwara
26
Apr 16, 2005 04:22 AM
OEMcivic
Jan 5, 2005 08:20 AM
drunknbass
Aug 18, 2004 08:21 PM
Halo
May 2, 2002 01:11 PM
