help crx turbo timer wiring!!!!!!!!!!!!!
okay i have a greddy timer and need help wiring it up to the ignition... did my search and found only EG ignition wiring........ i knoe alot of you have crx turbo out there... could you tell me what color the wires are on the ignition side ACC,ON, IG1,IG2,12v.... i think there were 3 colors from the greddy timer. red green and blue...
basically i need to knoe what connects to what and i dont have a helms manual for crx... oyeah what does the purple wire connect to? is it RPM or SPEEDOMETER?
ASAP .... turbo is in and any recommendations on how the radiator can be modified to work??? i knoe changing cross members or shorter radiator but how about stock eg one?
oyeah its an 88si b16A
