help car wont start please
Old May 7, 2008 | 08:32 PM
418whpturboD's Avatar
Default help car wont start please
ok so my turbo b16 civic wont start.. it instantly floods when i go to start it.. the car has been running fine and all the sudden started this.. it is tuned on crome. with an ostrich 2.0.. the fpr is working and the map sensor volt tested fine.. i cant figure it out.. cud it be a glitch in crome.. i un hooked battery and re hooked to reset and it didnt do anything... any help wud be awsome
Old May 8, 2008 | 02:45 AM
DaveF's Avatar
Default Re: help car wont start please (418whpturboD)
recently a friend of mine had a similar problem. turns out something happend between the time it was tuned and when the problem occured, causing the car to be completly rich. it was fixed by getting rid of fuel from the map. this car was also on crome i belive.
contact honda-tech user "93turbo16" --> https://honda-tech.com/zerouser...85635
or "boostedblkef" ---> https://honda-tech.com/zerouser...44764
Old May 8, 2008 | 03:03 PM
Default Re: help car wont start please (DaveF)
bump
Old May 8, 2008 | 08:18 PM
ok so i just tried about everything.. i turned the fpr all the way down, i changed ecu's, changed ostriches, took out all the fuel in the map, and it still drowns the plugs when i turn it over.. i dont no what elso to do any one?
Old May 9, 2008 | 05:58 AM
ham's Avatar
ham
prob a problem with the fuel map. i had the same problem with my 1000cc injectors on crome. try putting stock injectors in and see what happens.
Old May 10, 2008 | 10:03 PM
Default Re: help car wont start please (ham)
bump any one know wats wromg?? i cant figure it out.. cud it be a pick up in the dizzy that tells the injectors when to fire?? i have tryied 2 diff ecu's.. a different ostrich, and it still does it.. i have reset crome and tried taking all the fuel out of the settings and it still just drinches the plugs like 3 seconds after trying to start it....
Old May 11, 2008 | 11:37 AM
anyone....
Old May 19, 2008 | 11:21 PM
riddlinkid1986's Avatar
bump! same issue!
Old May 20, 2008 | 08:46 AM
Default Re: help car wont start please (riddlinkid1986)
turned out to be wires in the pre engine harness were ripped open and were grounding out on fire wall
BoostedH22__
Feb 1, 2016 11:33 AM
dc2_daj10
May 27, 2010 02:58 PM
Dueceification
Apr 1, 2007 05:26 PM
Easyslider01
Honda S2000
Feb 1, 2007 11:55 AM
JDMRACER689
Aug 19, 2006 09:39 AM
