Heli Coil block for head studs?
I've seen it on single cam once that ran high 20s on base map. It most likely happened thanks to some slight detonation. Helocoil and retune it.
Timeserts FTW. I am a technition a GM Garage. Cadillac Northstar engines between the year of 97-01 had a problem with the threads pulling out on the back head between 3/5 cylinder. We always drill the tread out and timesert it. We always go the extra step and do every thread. Because that engine is commonly known to pull threads. Considering its the same aspect, Honda/Cadillac both use Alum. blocks, I would Timesert it.
timecerts?
I know there are proven methods that work and I have read numourous threads on here so please I am just trying to learn a thing here
I take it most of you running these are making 600+whp/running more than 35psi?In the image below,the user installed ARP head studs right into the block but I did not find any content in his threads that stated he used a helicoil to keep the studs in check or another method...
Modified by Voltere at 11:14 PM 11/1/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 »</TD></TR><TR><TD CLASS="quote">Timeserts are much better than helicoil.</TD></TR></TABLE>
Is this what everyone is using?
Has there been cases of people pulling threads out the blocks?
bought a timesert kit two years ago to fix a d-series block that had two stripped head stud holes after bad overheat. after repair, was able to torque to oem specs and motor is still running with over 200k on it.
if you need a d-series kit, i still have it, you just have to order the timeserts themselves. they're like a dollar.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voltere »</TD></TR><TR><TD CLASS="quote">
Has there been cases of people pulling threads out the blocks?</TD></TR></TABLE>
It happens due to incorrect install or overheating the block.
TIMESERTS FTW.
I broke down a while back and bought the complete Honda/Acura timesert kit which was not cheap $350.00 approximately. I have fixed numerous blocks using the kit and have not had 1 come back with any problems. I even had one customer with an LS block that was Helicoiled in all 10 holes. I pulled the coils out and installed a full set of timeserts and the car has been running for over a year now. The kit paid for itself after using it only 6 times. The best money I have ever spent IMO.
no, these people are only using them cuz they [freak]ed the threads in the block up. i can't imagine all the threads being pulled out by high cylinder pressure produced by our motors.
correct me if I am wrong but I don't think any of your stud holes are stripped. Your just wanting to install timeserts or helicoil because your worried that boosting 35+ psi will strip them.. not gonna happen...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fumatch »</TD></TR><TR><TD CLASS="quote">bottom line is that steel threads are going to be a lot more stronger than aluminum threads.</TD></TR></TABLE>
do you see the flaw in this statement?
heres a hint: the inserts are still in aluminum so its still gonna have a weak link.
as said in almost every post here, timeserts > *.*
used them in a non honda application and they were great and still holding up from what i understand (dont have the car anymore).
A timecerted hole, if properly done is stonger than a stock alum threaded hole. Normally more threads per inch in metal is stonger but alum is so soft that courser threads are stonger, very similar to wood.
