headgasket thickness questions...did search
OK, so cometic offers 5 different thicknesses in their headgaskets.
.036 .043 .057 .098 .112 What is the stock size on a B18B? Is there a formula to figure how much the differences in thickness affect the C/R? Thanks. |
Re: headgasket thickness questions...did search (2K_TEG)
Re: headgasket thickness questions...did search (Arturbo)
cool, thanks...only one more ? though...if I have my standard combustion chamber (45cc) deshrouded to fit the 84mm bore what would the resulting cc be? Sounds like a question for dustin. haha
That is up to the person who does your work. Ask your machine shope once its done but it shouldnt be very much larger than 45cc.
art... |
Arturbo,
Where it says, oem-3, 2 or 1. Does that mean you can break down the OEM head gasket or do you buy a 2 or 1? |
Re: headgasket thickness questions...did search (WykidEG)
Arturbo, Where it says, oem-3, 2 or 1. Does that mean you can break down the OEM head gasket or do you buy a 2 or 1? |
I think they are saying you can divide the 3 layers to each layer. I think its .01" per each OEM layer. FYI, cometic uses a 3 layer just like stock...
art |
if I have my standard combustion chamber (45cc) deshrouded to fit the 84mm bore what would the resulting cc be? [Modified by 2K_TEG, 2:16 AM 5/2/2002] |
That's what I want to know. . . . . . ?
[Modified by WykidEG, 1:36 AM 5/2/2002] |
