HEAD GASKET?
Old Oct 27, 2008 | 07:17 AM
integraturbo's Avatar
Default HEAD GASKET?
IS ANY ONE HAVING TROUBLE WITH THERE HEAD GASKET ON A TURBOED LS MOTOR. I JUST RECENTLY REPLACED MINE AND NOW I AM FINDING COOLENT ON MY OIL.I A 3MM HEADGASKET.
Old Oct 27, 2008 | 07:52 AM
Death_to_Thieves's Avatar
Default Re: HEAD GASKET? (integraturbo)
Not me. is it an OEM gasket? how much boost? you have headstuds?
Old Oct 27, 2008 | 12:45 PM
Default Re: HEAD GASKET? (JAYSEM Society)
YEAH ARP HEAD STUDS. THE MOTOR IS FULLY BUILT, BUT IM HAVEING PROBLEMS WITH HEAD GASKETS IM THINKING THE DARTON SLEEVES WHERE NOT INSTALLED RIGHT BC THE SLEEVES DONT SIT FLUSH WITH THE HEAD AND IM PUSHING 15POUND OF BOOST DAILY.
Old Oct 27, 2008 | 04:38 PM
platinum00's Avatar
What do you mean they dont sit flush with the head. Do you have pictures.
Have you check the block and head for warpage using a straight edge and a feeler gauge?
-platinum
Old Oct 27, 2008 | 05:45 PM
yakuza's Avatar
is your caps key STUCK or something? Majority of us here enjoy good hearing, so please stop shouting and loose the CAPS.
Old Oct 28, 2008 | 03:54 AM
Default Re: (yakuza)
well lets say the head gasket is on the block my sleeves sit lower then the head gasket and the head & block are not worped. Ill have pic's in a few day for u guys.
Old Oct 28, 2008 | 12:14 PM
ABK's Avatar
ABK
Default Re: (integraturbo)
well that's the way you measure to check to see if block/head are warped, and too see if you sleeves started to sink. Was the motor ever overheated? You might want to pull the head off and check for warpage. Did you torque the studs right?
Is it cometic head gasket? If so is the a reason behind it because the motor has to be built, too high of the compression?
Old Oct 28, 2008 | 02:47 PM
platinum00's Avatar
If your sleeves sit lower then your block deck you are never going to get a good seal. If I understand you correctly your going to need to get your sleeves fixed.
-platinum
Old Oct 29, 2008 | 08:07 AM
Default Re: (platinum00)
im going to send it back to the machine shop to get it fixed
Old Oct 29, 2008 | 10:56 AM
ABK's Avatar
ABK
you should check first because you don't know what you need to fix. If you could tell just by looking at the sleeves that they are sitting lower then the deck your car would not start and your engine would take like 4 gallons of coolant to fill it up, lol.
Simon Szuba
Honda CR-V & Element
May 26, 2021 11:37 AM
MigsD16
Engine Machining & Assembly
Dec 17, 2016 05:17 PM
flozella
Aug 30, 2014 07:20 PM
strike1545
May 24, 2010 10:42 AM
-Darren-
Jun 2, 2009 03:54 PM
