Have you done this before?
Old Mar 5, 2010 | 06:12 PM
Seraph0's Avatar
Default Have you done this before?
So I reassembled my head and torqued down my head studs today. Got everything back together and realized I had two parts leftover. The two dowels that go between the block and the head. #$%#$%$#^%%$%$###%!!
So to stay techinical. My question is.. Can I remove it apart and will the head gasket still be ok to reuse?
Old Mar 5, 2010 | 07:47 PM
HickamHatch's Avatar
Default Re: Have you done this before?
You will want to get a new headgasket once it has been torqued down no matter if it has 0 miles or 10,000 miles, it has already been torqued. And 99% chance it wont line up the same since the dowel pins were left out when it was torqued.
Old Mar 5, 2010 | 09:06 PM
ctr32's Avatar
x2
Old Mar 7, 2010 | 12:01 PM
Seraph0's Avatar
Thanks guys. That's not what I wanted to hear, but I need this thing to be 100% solid.
And now guess what. I broke a stud in the block. @#$#@%%#!! I got it out w/o damaging anything, but damn this is not my weekend for good luck.
Old Mar 7, 2010 | 12:19 PM
Kyle R's Avatar
Sorry to hear that. Good luck getting everything back together.
Old Mar 7, 2010 | 06:45 PM
EKlscoupe_98's Avatar
Sounds like your luck was like mine today. Best of luck getting it up and running again.
Old Mar 7, 2010 | 08:27 PM
10sec4door's Avatar
Damn we all had bad luck this weekend. Im assemblying my motor, the head had been on for a while w/o spark plugs. I went to do a compression test and noticed something in cylinder 1. Had to take the head off. I had a #@@#$@$% Walnut in my motor. Gdamn spuirl must have been in the garage. If I see that bstrd Im putting a 9mm in his ***. Well Im so frustrated with this build I just put the head back on and torqued it down with more ft/lb.
Old Mar 7, 2010 | 08:35 PM
TylerB's Avatar
You ever read a honda tech thread and wonder if you forgot your dowel pins in your freshly built motor? Are they essential?
Old Mar 7, 2010 | 09:32 PM
ali954's Avatar
when i did my b20vtec i didnt have the dowel pins in the first time and it was all ****ed up. so i got the dowel pins, arp head studs, and a honda head gasket and shes great now. the honda head gasket has like a strip in it that makes it bow to help when torqueing as opposed to the cometic one i had that just laid flat.
Old Mar 8, 2010 | 08:45 AM
Seraph0's Avatar
It's good we can still come to Honda-Tech and laugh at our misfortunes. I was debating whether to just forget about the dowel pins and running with it, but I don't have experience with exactly how important they are.
Anyway... going to call Golden Eagle in a little bit to see if I can order ONE headstud and a new headgasket. :\
I copper sprayed the gasket too and now my nice perfectly-clean-from-the-machine-shop mating surfaces are gunked up with copper. Wonder if I can find an aluminum friendly copper solvent to clean up the deck/head. Wonder if E85 will get 'er done.
Old Mar 8, 2010 | 01:16 PM
Bailhatch's Avatar
Acetone will get the copper spray off nicely. What studs do you need? I have a set of b16 GE studs that have never been torqued, just threaded into a block.
Old Mar 8, 2010 | 01:27 PM
Seraph0's Avatar
Acetone... Cool, Thanks.
I need just one GE head stud for a GSR block. I don't think the B16 ones will work.
I didn't get a chance to call GE today either.... blah.
Old Mar 8, 2010 | 01:57 PM
Bailhatch's Avatar
No they won't work. Good luck!
weekendboost
Apr 18, 2014 04:45 AM
1POINT8L
Jul 22, 2008 07:19 PM
Day-DayC
May 18, 2006 08:51 PM
sporkcrx
Apr 8, 2004 09:03 PM
servion
Mar 7, 2003 08:35 PM
