GT35 vs SC61
Old Nov 11, 2005 | 05:35 PM
markaria's Avatar
Default GT35 vs SC61
Sorry to post this, but the search feature seems to be down. Wondering the pros/cons of the sc61 vs the gt35 and how they compare...
on a built/sleeved b18c
-anyone try both?
-pump gas #'s (15-17psi w/9:1 compression)?
-any other additional input?
-is the xtra $ worth it?
thanks for any help in advance
Old Nov 11, 2005 | 05:46 PM
BlueShadow's Avatar
Default Re: GT35 vs SC61 (markaria)
Check out http://www.evans-tuning.com in the dyno charts forum for charts so you can compare the two. I was comparing the two a while back and IIRC the 35R usually had better mid range since it spooled earlier. I believe it spooled about 1000 RPM's sooner then the SC61 and it had about ~100 more HP at mid range RPMs.
Old Nov 11, 2005 | 07:10 PM
D@nnY's Avatar
35R owns the sc61
Old Nov 11, 2005 | 07:18 PM
BlueShadow's Avatar
Default Re: (D@nnY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY &raquo;</TD></TR><TR><TD CLASS="quote">35R owns the sc61</TD></TR></TABLE>
About the only place the GT35R doesn't "own" the SC61 is in the price.
SC61 = poor mans GT35R
Old Nov 11, 2005 | 09:16 PM
Sprockets's Avatar
Default Re: (BlueShadow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueShadow &raquo;</TD></TR><TR><TD CLASS="quote">SC61 = poor mans GT35R </TD></TR></TABLE>
Actually, the GT35E = poor man's GT35R
Old Nov 11, 2005 | 09:37 PM
Makdaddynuge's Avatar
i have a feeling he isn't comparing the sc61 with the 35R but with the 35E. Because there really isn't no comparison with the 35R.
Old Nov 12, 2005 | 07:20 AM
BlueShadow's Avatar
Default Re: (USE2B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USE2B16A &raquo;</TD></TR><TR><TD CLASS="quote">
IMO so is the SC61 with the S cover. Same comp housing a/r, same GT35R comp wheel just no BB. But the SC61 with S housing is priced at $800-$850. I believe that's the same price as the GT35E.
Old Nov 12, 2005 | 10:52 AM
markaria's Avatar
any other opinions? Any idea on the difference between the gt35e and the sc61?
...so between the gt35r and sc61 it isn't even a comparison?!?
Old Nov 12, 2005 | 12:30 PM
JDogg's Avatar
Default Re: (markaria)
as far as i know the turbos have the same compressor, just a different turbine.
from my experience, the 35r will spool a hair faster, has a ton better throttle response and will make more power than the sc61. i have never used a 35e
Old Nov 12, 2005 | 02:25 PM
markaria's Avatar
Default Re: (JDogg)
thanks
Old Nov 12, 2005 | 02:39 PM
tokesGTR's Avatar
Default Re: (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">as far as i know the turbos have the same compressor, just a different turbine.</TD></TR></TABLE>
Yessir. Both run the 56-trim GT35R compressor wheel. GT35E uses the GT35R turbine wheel, while the SC61 uses a Stage V T3 wheel or a P-trim wheel.
Old Nov 12, 2005 | 03:36 PM
h22 civic's Avatar
Default Re: (tokes1320)
u will be happy with the 35e
Old Nov 13, 2005 | 05:04 AM
PRELUDE-GT35R's Avatar
Old Nov 13, 2005 | 08:02 AM
seen4ever's Avatar
Default Re: (PRELUDE-GT35R)
I &lt;3 my gt35e. 393whp&270wlbs@14psi, 480whp@19psi.
Old Nov 19, 2005 | 04:33 PM
kamAccord's Avatar
https://honda-tech.com/zerothread?id=1291417
BuBBa y0!
Jun 1, 2011 06:43 PM
stroker8950
34
Jun 19, 2008 06:32 PM
spoolin turbo s
Jan 2, 2007 08:39 PM
Dr Pooface
Apr 1, 2006 03:40 PM
