gt3076r rated
here are some pics of my rusty ol honda. still needs to get tuned dont what program i wanna run.
how much can you squeez a gt3076r too on a fully built setup race gas of course
psi
hp
psi
hp
With the right exhaust, you can get quite a bit from it. It also spools about as fast as any turbo it's size. This is a gt30r vs a gt35r (read the specs):
http://forums.evans-tuning.com/viewt...hp?f=15&t=2931
The only difference is you have projector headlights - those will add 25hp. Another 15hp if you have ricetezzas.
Cooling WILL be an issue if the DP is left unwrapped, no ducting is added in front of the rad, and if you have don't have a full shroud for the fan (ala Tony1's design). Even worse if it's an ebay-special fan that claims 3200cfm.
why do you have the downpipe go behind the radiator? I have mine setup just like that, but I have my 4'' downpipe go in front of the radiator and out the side with zero cooling issues.
ohhh yea hes gonna be ballin. them lights make that car also lose like 55lbs over the factory ones to
....but answer to ur question i think its somewhere in the 500's im not a 100% sure but somebody chime in and let him know
The compressor wheel itself is rated or about 52-53 lbs/min--so roughly a low 500 whp turbo.
http://www.turbobygarrett.com/turbob..._700382_12.htm
the first build i had with the dart block was 81mm setup and it made 377whp at 14psi and 300ftlbs 14psi n that was on a log manifold with smaller everthing i just got a complete rebuild 84.5mm and topmount mani with 3" everthing looking to do atleast 550 on race gas and pump gas im only lookin for 450whp
I can't wait for you to run your car at the track and watch your slicks expand while racing and hit your dp and pop.
Seriosuly thats not a good idea to have that there.
yeah that dp is pretty close to the tire, be careful with expansion of the tire at the track. That raditor on that nagle and so far from the front of the car like that is going to have cooling issues even with a good fan. all the air is going to go around it and not through it
and it goes in front of the traction bar.
https://honda-tech.com/forums/forced-induction-16/650whp-30r-2644891/
But hope for about 480hp and 580hp on E85... reliability is my priority
