GSR vs. B16 cams for boost.
Old Apr 14, 2006 | 01:42 PM
Ryan C's Avatar
Default GSR vs. B16 cams for boost.
Ive heard that the GSR's are considerably better. Is this true.
TIA
Old Apr 14, 2006 | 01:46 PM
1320me's Avatar
Default Re: GSR vs. B16 cams for boost. (Ryan C)
itr.s is the way to go
Old Apr 14, 2006 | 01:50 PM
adictionbass's Avatar
yes gsr cams make more power. itr even more.
Old Apr 14, 2006 | 04:40 PM
quicksilver1689's Avatar
i ♥ snails
Dont mean to thread jack but, why are itr cams so good for forced induction? I thought valve overlap isnt the best for F/I? or is it just excessive overlap that can be bad?
Old Apr 14, 2006 | 05:10 PM
Tactic$'s Avatar
I was under the impression that you can dial out the overlap with adj. cam gears. I dont run cam gears with my CTR's, so I wouldn't know for fact.
+1
Old Apr 14, 2006 | 05:20 PM
SpeedingHatch's Avatar
Default Re: (Tactic$)
It goes like this for OEM Honda cams for boost:
EDIT
b16<GSR<ITR
GSR's usually are around 100 bucks and ITR considerably more (~250 I think)
Im running GSR's in my b16
Modified by SpeedingHatch at 12:48 AM 4/15/2006
Old Apr 14, 2006 | 06:13 PM
Blackack26's Avatar
Default Re: (SpeedingHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedingHatch &raquo;</TD></TR><TR><TD CLASS="quote">It goes like this for OEM Honda cams for boost:
b16&gt;GSR&gt;ITR
Im running GSR's in my b16</TD></TR></TABLE>
Umm I think you mean b16&lt;GSR&lt;ITR
Old Apr 14, 2006 | 08:47 PM
Default Re: (Blackack26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blackack26 &raquo;</TD></TR><TR><TD CLASS="quote">Umm I think you mean b16&lt;GSR&lt;ITR</TD></TR></TABLE>
Woops. Yeah. Math pwns me
Old Apr 15, 2006 | 02:47 PM
Ryan C's Avatar
Default Re: (quicksilver1689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 &raquo;</TD></TR><TR><TD CLASS="quote">Dont mean to thread jack but, why are itr cams so good for forced induction? I thought valve overlap isnt the best for F/I? or is it just excessive overlap that can be bad?</TD></TR></TABLE>
not jackin at all, good question
anyone add to that?
Old Apr 16, 2006 | 12:25 PM
Meet07's Avatar
Default Re: (Ryan C)
Ive seen a write-up on evans-tunning that the gsr cams dialed in with cam gears can make anywhere from 20-60 extra hp.
Old Apr 16, 2006 | 08:44 PM
Ryan C's Avatar
Default Re: (Meet07)
20-60 whoa
Old Apr 16, 2006 | 11:00 PM
mrx's Avatar
mrx
i have a stock b16a1 engine and only the stock single exhaust springs ... is there any way to use gsr, itr or ctr cams without upgrading the valvetrain or is there a cheaper solution for upgrading the valvetrain without buy a one from crower i.e.?
i want to use other cams but i'am unsure about if the powergain is worht the ~1000 $ for cams and valvetrain
Old Apr 18, 2006 | 05:51 AM
sp00led's Avatar
Default Re: (mrx)
I have a extra set of gsr cams if anyone needs them.
Old Apr 18, 2006 | 10:00 AM
Blackack26's Avatar
Default Re: (mrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrx &raquo;</TD></TR><TR><TD CLASS="quote">
i want to use other cams but i'am unsure about if the powergain is worht the ~1000 $ for cams and valvetrain</TD></TR></TABLE>
You could also use ITR springs and retainers, they go for around $100 for everything.
Old Apr 18, 2006 | 11:06 AM
raene's Avatar
It depends on your manifold and turbo setup. A typical log won't see much gain from ITR cams, but an equal-length and a large turbo (ie low backpressure so less reversion), will. Remember typically you have higher EM pressures than IM pressures so you get backflow into the engine under FI. With a high-flow manifold, you see much lower pressures in the manifold, so you get less backflow and more power. It's all about matching your setup.
"Blowing boost through" the head is basically nonexistent unless you have lower backpressure in the exhaust manifold than in the intake manifold, which just isn't the case 99% of the time.
Wilka
Dec 9, 2012 01:41 PM
JustHere4ADay
Dec 17, 2007 08:37 AM
sonny0330
Jul 18, 2007 01:24 PM
turbochargeb18c
Sep 7, 2005 05:13 AM
Charlie Moua
Mar 31, 2003 08:30 AM
