block...
84.5mm sleeve
wiesco 9.1 pistons
JE rods
ARP head studs
Head
full rev valvetrain
sk2 stage 2 cams
sk2 pro series cam gears
fuel
walboro 255 fuel pump
1000cc injectors
AEM fuel rail
turbo
t3/t4 turbonetics .50
ram horn manifold
a piece of **** wastegate that will get changed
so on 20 or so pounds of boost what should i be around whp??
84.5mm sleeve
wiesco 9.1 pistons
JE rods
ARP head studs
Head
full rev valvetrain
sk2 stage 2 cams
fuel
1000cc injectors
AEM fuel rail
turbo
ram horn manifold
which T3/T4? .50 is an incomplete statement. that could be from a 50trim to a 61mm turbocharger. Please measure your wheels on the turbo (not just the numbers on the housings) and if you could, be more specific.
Also remember in our forum rules about HP guesstimates and benchracing. this is not allowed.
Mr. Badwrench
considered bench racing. you will have to find out.
