GSR Turbo Question
I have a gsr that i want to boost. my question is, is it safe to run 8 psi DD on stock internals?
also is it better to internal wastegate or external for a low psi DD setup? also what kind of turbo should i run?
Watch out man your going to killed with bad responses...you should probley search around there is tons on info on setups like this...
Yes you can run 8psi dd as long as its tuned right, and you have a good turbo setup it will be reliable and safe...For the turbo part you can run anything depending on your power goals..A simple t3 50trim would be fine quick spool for dd...all depends what type of power goals your looking for..
https://honda-tech.com/forums/forced-induction-16/%2A%2A%2Aforced-induction-forum-faq%2A%2A%2A-1024174/
boosting your dd isnt a problem if you know what you are getting into and can build it safely within budget and goals in mind.
read the faq's and search around.
