GREDDY TT
Old Oct 17, 2005 | 07:56 PM
Metzler's Avatar
Default GREDDY TT
i have a greddy full auto turbo timer and its all hooked up with the harness they gave me...it doesnt stay on and keep the car on after i turn the key off...it just flashes off and turns off with the key?
Old Oct 17, 2005 | 08:18 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: GREDDY TT (Metzler)
is the e-brake on?
Old Oct 17, 2005 | 08:20 PM
Bailhatch's Avatar
Default Re: GREDDY TT (wantboost)
try the switch on the back maybe. or wire it correctly?
Old Oct 21, 2005 | 10:23 PM
Metzler's Avatar
Default Re: GREDDY TT (Bailhatch)
do the e brake switch and speed sensore have to be hooked up?
Old Oct 22, 2005 | 03:02 AM
no2unenolife's Avatar
well the ebrake is a safety precaution on the TT ... so wire it up, other wise, it'll think the ebrake is down and won't keep ur car on
Old Oct 22, 2005 | 07:17 AM
nota-eg's Avatar
Default Re: (no2unenolife)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no2unenolife &raquo;</TD></TR><TR><TD CLASS="quote">well the ebrake is a safety precaution on the TT ... so wire it up, other wise, it'll think the ebrake is down and won't keep ur car on</TD></TR></TABLE>
And the speed sensor tells it how long to keep the car on (I think.)
Old Oct 22, 2005 | 10:22 PM
Metzler's Avatar
Default Re: (nota-eg)
how would that determing how long to keep the car on for?
Old Oct 23, 2005 | 06:10 AM
nota-eg's Avatar
Default Re: (Metzler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Metzler &raquo;</TD></TR><TR><TD CLASS="quote">how would that determing how long to keep the car on for? </TD></TR></TABLE>
I'm not really sure. It uses some signal to see how long the car was running and how hard it was running to determine how long the car needs to stay on to cool off.
Old Oct 23, 2005 | 08:29 AM
wantboost's Avatar
Who is Mr Robot?
the greddy tt uses bechicle speed and rate of acceleration to fiogure out how long to stay on based onthe mode the tt is set to and th e-brake switch is a safety measure... if its not wired up the car wont stay on.
Old Oct 23, 2005 | 09:15 AM
Soccerking3000's Avatar
Default Re: (wantboost)
WRONG, i have a greddy turbo timer and i do not have the ebrake nor the VSS signal hooked up and mine works perfectly fine i have never had a problem
Old Oct 23, 2005 | 07:39 PM
Metzler's Avatar
Default Re: (Soccerking3000)
yea i just figured it out...theres a little switch on the back and apparently i had it switched the wrong way.... how long do you guys normally keep your car on for? i have mine set to 2 mins 30 secs
Old Oct 23, 2005 | 07:54 PM
Quad-Damage's Avatar
depending on the way i drive 1 min and whatever else it goes up to
i don't use it 1/2 of the time just wait in my car anyways
Old Oct 23, 2005 | 07:59 PM
Default Re: (Quad-Damage)
i let mine run for 2-3 minutes depending
Old Oct 23, 2005 | 08:23 PM
nota-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">WRONG, i have a greddy turbo timer and i do not have the ebrake nor the VSS signal hooked up and mine works perfectly fine i have never had a problem</TD></TR></TABLE>
Is yours setup by YOU to stay on for a specific time?
I know Blitz has it so you can set the amount of time it stays on or it can calculate it automatically by vehicle speed and stuff like that.
Old Oct 24, 2005 | 03:22 AM
yes mine is hooked up to run for a specific time, obviously not from the vss
Old Oct 24, 2005 | 01:12 PM
nota-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">yes mine is hooked up to run for a specific time, obviously not from the vss </TD></TR></TABLE>
Well there ya go.
The VSS wire is for the automatic timer. It wouldn't be there if there was no reason for it.
But it seems as though the OP figured out the manual timer, so he's good to go.
Old Oct 24, 2005 | 02:23 PM
well its also there so if the car moved at all when its counting down it shuts down
Old Oct 24, 2005 | 06:06 PM
nota-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">well its also there so if the car moved at all when its counting down it shuts down</TD></TR></TABLE>
I didn't know that. I have to wire up my half melted HKS turbo timer soon. As soon as I find a wiring diagram.
Old Oct 24, 2005 | 07:25 PM
epic1si's Avatar
actually the greddy TT uses the RPM's to calculate the time to cool off. i don't have a vss hooked up and my time will go up if i set it for automatic calculation. i just set it for 3 minutes though since that's what was recomended to me by a turbo rebuild shop.
Old Oct 24, 2005 | 07:27 PM
jrponline's Avatar
did you make sure that one the 2 ignitions wires were properly wired? one should be ignition, the other 12v constant.
Varao
Feb 4, 2009 03:43 PM
UnKnOwNsLeEpEr
Apr 17, 2006 06:33 AM
Metzler
Oct 1, 2005 07:00 PM
EGDC2CIVIC
Audio / Security / Video
Apr 22, 2005 02:46 PM
Stu22
Apr 13, 2005 11:02 AM
