Greddy GSR DP on LS
Old Oct 19, 2003 | 08:52 PM
DeadLock23's Avatar
Default Greddy GSR DP on LS
I bought a gsr turbo kit for my ls, its the greddy kit
anyways i found out that the dp is too short since the gsr apipe is shorter, do you know if i get the gsr cat, will it fill in the 2 inch gap and still bolt to my ls catback?
also the gsr has the o2 bung in the beginning of the cat for OBD1 as far as i know, will i be able to use my o2 senson there, because the dp doesnt have the bung for it?
thanks
Old Oct 19, 2003 | 09:04 PM
BlackKnight7's Avatar
Default Re: Greddy GSR DP on LS (DeadLock23)
Why don't you just weld, or get someone to weld some sort of extension on to your dp? I think that would be cheaper than buying a cat. I mean theres not a lot of labor required.
Jake d.
Old Oct 19, 2003 | 09:32 PM
MachAF's Avatar
Just have a shop extend the downpipe by two inches. Should cost like $50.
Old Oct 20, 2003 | 05:12 AM
DeadLock23's Avatar
yea that was my next option, to exrend the GSR dp to LS spec and add an o2 bung, is that how thw LS DP fro mthe greddy is? with the 02 bung in the DP?
I might even get a 2.5 DP while I'm at it...
any other suggestions? anyone have a greddy LS DP and need a GSR DP?
Old Oct 20, 2003 | 05:31 AM
dabrown's Avatar
I had the same issue, however after looking at that downpipe you may want to have a custom downpipe made with a bigger diameter. I went 2 1/2 and it you can feel the difference.. They can use the ends of your existing downpipe..
Old Oct 20, 2003 | 05:32 AM
DeadLock23's Avatar
whats a good estimate on the pricing for a new 2.5 DP?
and again will there be fitting issues?
Old Oct 20, 2003 | 07:39 AM
quikB18B's Avatar
Default Re: (DeadLock23)
Revhards 2.5 sell for about $150-$160, then you just need flex pipe and a flange
Lro255
Apr 5, 2008 05:27 PM
MachAF
Jun 30, 2003 09:01 AM
tC_Dragon
Oct 18, 2002 11:15 AM
redteg1
Oct 9, 2002 05:21 PM
