Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   greddy gauge install.. (https://honda-tech.com/forums/forced-induction-16/greddy-gauge-install-170821/)
bruthaboost Apr 23, 2002 02:27 PM
Hey y'all,
I'm installing some greddy gauges and I'm wondering where did all y'all patch in the parking light source line? It's the white wire on the greddy wire harness.
Flamenco-T Apr 23, 2002 10:33 PM
Re: greddy gauge install.. (b18bpwr)
jeff, I tapped it in the instrument light fuse... the purpose is so that when your cluster is on, the gauge is on, when it;s off, it's off
stan
bruthaboost Apr 24, 2002 07:07 PM
Re: greddy gauge install.. (Flamenco-T)
Many thanks stan.
ElectronVTEC Apr 24, 2002 07:17 PM
You can also use the illumination lead going to your radio if you have a Helms wiring code handy. HTH, EV.
adam Apr 24, 2002 07:51 PM
Re: greddy gauge install.. (ElectronVTEC)
or GRN/RED coming from the headlight switch, that wire gets signal when you turn on the parking lights
Krazy613 Jun 27, 2017 09:59 AM
ive always used the pins on the fuse box. Just have to fuse your wire coming off the fuse box pin.
Schister66 Jun 27, 2017 10:50 AM
You should check the dates before posting. This thread hasn't been active for over 15 years....If the OP hasn't figured it out by now, its not getting fixed
