Greddy eManage (bluebox) question?
Hallo,
can someone tell me if it is possible to use both, the add-on harnesses for Fuel Injectors AND the Ignition Harness on the eManage (classic) at the same time?
because the manual sayes that there are two seperate harnesses for Injectors and Ignition and the manual shows only one additional connector for add on harnesses.
maybe someone with a eManage running can make a picture of the connector side of the device.
PS: is there a special eManage forum where i can find some more informations about the eManage and the eManage Ultimate and how to tune them?
Thanks
Thanks
there is only 2 plugs on the emanage blue. One of the harnesses doesnt come with a plug and you have to push the connectors into the plug that came with the other harness.
sundownz
Feb 13, 2007 04:38 PM
