GReddy blue box question
Old Jul 1, 2003 | 09:39 PM
CHK4TIX's Avatar
Default GReddy blue box question
ok, i searched but i cant find what i need. Does anyone know if you can use the Greddy blue box which comes with the turbo kit for a 97-00 prelude on a 94 lude? my main question is will it cause problems since the 97-00 is obd2 and the 94 is obd1? Also if it wont work does anyone have suggestions on a fuel management route that i can take for the turbo?
Old Jul 1, 2003 | 11:00 PM
hondatool's Avatar
i dont think it will work, the harness is probably different and the boxes are usually set up for the engine it is put in...u can put it in but ur fuel curves and timing etc might be wacky
Old Jul 1, 2003 | 11:08 PM
CHK4TIX's Avatar
Default Re: (hondatool)
anyone else have any opinions on this?
Old Jul 2, 2003 | 06:18 PM
CHK4TIX's Avatar
Default Re: (CHK4TIX)
what knowbody has ever done this before to know, come on someone must know
Old Jul 2, 2003 | 06:42 PM
MachAF's Avatar
Won't work.
Old Jul 2, 2003 | 09:58 PM
CHK4TIX's Avatar
Default Re: (MachAF)
ok thanks.
Old Jul 2, 2003 | 10:04 PM
Daniel's Avatar
Default Re: GReddy blue box question (CHK4TIX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHK4TIX &raquo;</TD></TR><TR><TD CLASS="quote">if it wont work does anyone have suggestions on a fuel management route that i can take for the turbo?</TD></TR></TABLE>
aem ems, a'pexi power fc w/ commander option, hondata, those are just three among many that will work well on boosted applications.
Old Jul 2, 2003 | 10:51 PM
inline976's Avatar
it won't work and that blue box is pretty crappy. you should use the poor man's hondata....The v-afc. That's what I'm using and it works pretty good.
Old Jul 3, 2003 | 02:44 AM
CHK4TIX's Avatar
Default Re: GReddy blue box question (inline976)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inline976 &raquo;</TD></TR><TR><TD CLASS="quote">it won't work and that blue box is pretty crappy. you should use the poor man's hondata....The v-afc. That's what I'm using and it works pretty good. </TD></TR></TABLE>
thanks Inline, thats what i think im going to have to do. I am getting the turbo for a great price and it will be my first adventer in the world of FI, so i am hoping i can figure this out without to many issues
Old Jul 3, 2003 | 02:46 AM
inline976's Avatar
Just make sure you use some bigger injector, like some dsm 450cc's. That'll do the trick.
Old Jul 3, 2003 | 02:50 AM
CHK4TIX's Avatar
do you think that RC 370cc will work ok or should i get bigger ones?
Old Jul 3, 2003 | 02:56 AM
inline976's Avatar
I'm running 370's with an fmu and AEM fuel rail. You should probably just get the dsm 450cc's so you can run the v-afc hack properly.
Old Jul 3, 2003 | 03:01 AM
CHK4TIX's Avatar
ok, thanks again
Old Jul 3, 2003 | 11:42 AM
JOSEPH's Avatar
you can use the blue box from a obd2 prelude to obd1. it works. Take it from me. Im currently running this setup on my 93integra obd1 turbo. The blue box im using is for a 97up integra gsr.
I've had this setup for a while now and it works great. Im currently running 8.5 psi and this car is daily driven. Idle's perfectly, no problems starting, with a/c also
Old Jul 3, 2003 | 12:17 PM
CHK4TIX's Avatar
Default Re: GReddy blue box question (JOSEPH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOSEPH &raquo;</TD></TR><TR><TD CLASS="quote">you can use the blue box from a obd2 prelude to obd1. it works. Take it from me. Im currently running this setup on my 93integra obd1 turbo. The blue box im using is for a 97up integra gsr.
I've had this setup for a while now and it works great. Im currently running 8.5 psi and this car is daily driven. Idle's perfectly, no problems starting, with a/c also </TD></TR></TABLE>
I was able to find some wiring charts for a few different models and they all seem to hook up the same way. When you hooked your up did you have a hard time locating the wires or were they in the same place as the obd2? (as far as pin #)
badasshatchhh
Jun 30, 2005 08:33 PM
fastcivicboy
Oct 12, 2003 12:06 PM
gen4h22a
Oct 4, 2003 06:20 PM
mey_xanng
Oct 5, 2002 01:31 PM
dynamic696
Jul 28, 2002 10:10 AM
