Greddy blue box question...
Old Mar 26, 2005 | 01:34 AM
lDanny's Avatar
Default Greddy blue box question...
note: im a newbie, and i have a d16y8
so i did a search and this is what i came up with.... if i use a blue box then i dont have to use a fmu, its ok for a stock motor (injectors) if i keep it between 7-8psi... my questions is that if i piece together my own kit, can i still use the blue box? TIA
Old Mar 26, 2005 | 02:10 AM
supercharged18g's Avatar
Default Re: Greddy blue box question... (lDanny)
the blue box is actually made to run on 5lbs,yes you can use the blue box for make your own kit all it does is let the map sensor accept boost,i say junk the blue box and buy hondata, if you got the money
Old Mar 26, 2005 | 08:23 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: Greddy blue box question... (supercharged18g)
I'm running the blue box on stock fuel pump/injectors on my Y8, with a 2 degree timing retard. It's running fine, but I wouldn't run more than 7-8 psi without upgrading your fuel pump.
Old Mar 26, 2005 | 09:30 AM
SOHCmaster's Avatar
Im running 10psi all day for over a year w/blue box and have no issues at all and I have a wide band to make sure its ok. Also 255 walboro
I just cant run a missing link to turn it up more due to the blue box wont accept the link
Old Mar 26, 2005 | 10:29 AM
lDanny's Avatar
Default Re: (PK SPEED)
the wastegate controls the boost right?
Old Mar 26, 2005 | 05:28 PM
SOHCmaster's Avatar
Default Re: (lDanny)
I was refering to using a missing link to go beyond 10psi w/blue box but the link and blue box dont jive with hiding the MAP.. My stock map throws a code when I turn it up beyond 10psi.. Other than that I have no issues with the blue box. So far so good..
Old Mar 26, 2005 | 10:15 PM
Evo-man@20psi's Avatar
Old Mar 30, 2005 | 01:47 PM
b1ackc1v1c's Avatar
stock injectors...gsr fuel pump...been boostin for 3 months and no problems...just dont get to crazy good luck with the set-up and i see "boostincoupe" gave his advice that man knws what he's talkin no bs
Old Mar 30, 2005 | 02:14 PM
Default Re: Greddy blue box question... (b1ackc1v1c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b1ackc1v1c &raquo;</TD></TR><TR><TD CLASS="quote">stock injectors...gsr fuel pump...been boostin for 3 months and no problems...just dont get to crazy good luck with the set-up and i see "boostincoupe" gave his advice that man knws what he's talkin no bs</TD></TR></TABLE>
Alright, well let's flip the script. Here's something you can help me with.
How'd that GSR fuel pump install go?
Bimmerman
May 6, 2005 04:30 PM
eNRGyNiX
Apr 17, 2005 09:39 AM
kranked91dx
Nov 20, 2003 05:03 PM
boostincoupe
May 20, 2003 03:29 PM
Maverick77
Nov 12, 2002 02:13 PM
