Going SC on a B18C...need some advice
Old Nov 6, 2007 | 02:34 PM
JuicyJDM's Avatar
Default Going SC on a B18C...need some advice
I was wondering if anyone could touch on lowering the compression with a head gasket spacer. I heard HKS makes a nice one. I have a B18C that I want to run a JRSC with the upgraded boost pulley. Should be about 7.0 lbs of boost according to the Jackson tech. Anyway, I know it would be safer to run the higher boost with lower compression, but I don't want to change the pistons. I'm going to use 440 cc injectors and I'm trying to decide to go with hondata or crome.
Any help/advice would be greatly appreciated.
Old Nov 6, 2007 | 04:24 PM
urbansi's Avatar
Default Re: Going SC on a B18C...need some advice (JuicyJDM)
Hondata if you can afford it. Dont worry about the head gasket, the CR wont be that big of an issue.
Old Nov 7, 2007 | 02:14 PM
JuicyJDM's Avatar
Default Re: Going SC on a B18C...need some advice (urbansi)
Okay thanks! Do you have an idea where to get it. I would like to get a deal on it. I'm sure so does everyone else too.
Any other advice for this set up?
lsjon
Jun 18, 2009 12:25 PM
D1andOnly
Nov 27, 2005 05:00 PM
prennro
Aug 10, 2004 10:29 PM
joe pagolac
Aug 21, 2001 09:02 AM
