going external on a internal wastegate
Old Mar 26, 2009 | 12:56 PM
leroyb's Avatar
Default going external on a internal wastegate
hey well i have a internal turbo i think is a t3 is off a 2gen dsm and i wanted to go external they told me to get the lil door thing welded but ones i do that is there any thing else i have to do? and is the pressure regulated from the wastegate on the manifold? sorry if is a easy one but new to the turbo game
Old Mar 26, 2009 | 01:45 PM
accord_raffi's Avatar
Default Re: going external on a internal wastegate
the pressure will be regulated from the new External Wastegate. It works similar to the internal in a sense that the external wastegate is going to get it's signal from the turbo's compressor through the vac line. I think that is the answer you were looking for.
Old Mar 26, 2009 | 03:22 PM
leroyb's Avatar
yea pretty much
Old Mar 26, 2009 | 03:27 PM
omgwtfbbq's Avatar
weld the flapper shut, and run the vacuum line from the compressor housing to the new wastegate. If you have a boost controller, your setting will now change depending on the spring that your new external wastegate has.
Old Mar 26, 2009 | 03:33 PM
jdm602's Avatar
doesnt have to be off the compressor housing. could be off the im. and depending on what downpipe you use, like ive seen some 5bolt downpipes have just the turbine housing hole on the flange and not the wastegate hole that recircs back into the downpipe so that would also block the flapper.
Old Mar 26, 2009 | 05:20 PM
HiProfile's Avatar
Icon3 Re: going external on a internal wastegate
He'd want that flapper 'stuck' shut some how, by welding or wedging the flapper's swing arm closed. If its allowed to swing open, despite the hole behind it closed (like a DSM turbo could be), he'd have an area that fills with carbon. Not keeping it shut will also disrupt flow.
If you're new to the game, you should REALLY be reading the turbo FAQ's. Google it on google, the beesandgoats version explains 99% of the normal n00b questions.
Old Mar 26, 2009 | 06:21 PM
leroyb's Avatar
trust me i have been doing alot of reading watching youtube videos and searching but there is some stuff that i cant find answers too like this "Q"
turbodailydan
Jul 9, 2009 01:13 PM
ktran1
Jul 13, 2006 01:01 AM
SpoolnByYou
Dec 2, 2005 11:14 PM
killa_lude
Oct 1, 2003 04:59 AM
DA666
Apr 3, 2002 08:12 AM
