GE intake manifold
i have a h22 eg that i recently purchased a GE intake manifold and 70 mm str tb for. After port matching the TB flange and the manifold flange to my head, i noticed that it doesnt have a throttle cable bracket https://honda-tech.com/forums/images...es/emdgust.gif basically what im asking for is info on how i should mount the throttle cable. If anyone has pix of their setups that would be coo. Anyone with info, please help out... thanks in advance...
you have to make a bracket... its not hard just take the old one keep the side of the bracket that bolts on to the mani and cut and weld to what ever lenght you might need to make the cable work... make sure tb opens and closes all the ways also
Re: (fooleo's boosted)
you try using a gsr throttle cable bracket ? are there holes on the STR TB for that ? i hope there are , if so would be an easy fix to ur problem . https://honda-tech.com/forums/images/smilies/emthup.gif
i was layin down n just thinkin, n i think i figured out how the bracket would bolt to the manifold. =X the manifold doesnt have any wholes to mount the throttle cable bracket to but it came with a universal mount and i was trying to make it work but it was not on right. =X whoops!!!!!! ima try out the way that i just thought about... thanks for the help tho guys...
Re: (AVRh22EG)
i just got mine in also along with the 70mm throttle body
they make a throttle body cable bracket for $18 but i don't know how to mount it |
Re: (ebp 99 si)
im not sure, i havnt had a chance to make sure but i think i got it. my manifold is at the shop i work at and i havnt had a chance to try it out since i came up with it but i think it mounts with one metal bracket underneath the 1 and 2 runners and the other metal piece on top of the 1 and 2 runners. then they stay in place with the two allen bolts... and you put you stock throttle bracket to the wholes on the universal cable mount. let me know if you think this makes sense. https://honda-tech.com/forums/images...es/emdgust.gif
Re: (AVRh22EG)
me and a friend of mine was looking at it like that and scratching our heads
i believe it might mount like that but i'm still not for sure seems kinda ghetto but if it works thats all that matters |
Re: (ebp 99 si)
yea i just tried it today. it fits coo. kinda weird that the old bracket has to mount to it facing up instead of towards the valve cover but whatever. saves me time from having to get a bracket welded on. =\
Re: (AVRh22EG)
old bracket?
can u put a pic up for me |
