Which gauge has a smal scale? ->>
Old May 2, 2002 | 07:15 PM
escapist13's Avatar
Default Which gauge has a smal scale? ->>
I'm looking into getting a boost gauge and eventually and EGT. I really like the style of the Defi and the Apexi ones, and they are both around the same price ($120). However, on both of them, the pressure goes from 0 to 30 PSI in 180 degrees of needle travel. Now I know I am never going to be running 30 psi. Hell, my system is going to be supercharged, so I'm sure it'll never see above 15. So when I'm boosting and I look at the gauge, the needle might nudge a fifth of an inch to my (hopefully) desired boost. Not very helpful information. Is there a gauge that is similar to the above mentioned ones, but has a smaller scale of numbers? Maybe something like 0 to 20 PSI in 270 degrees of needle travel? Thanks for any info or suggestions you can give me.
Old May 2, 2002 | 07:25 PM
2K_TEG's Avatar
Default Re: Which gauge has a smal scale? ->> (escapist13)
Autometer makes a 15psi boost guage, I believe. I know for sure that they make smaller scales.
Old May 2, 2002 | 11:12 PM
turbod97ex's Avatar
New User
Greddy makes a reliable boost gauge that will do what you want - scaled down so that you can see the boost up to 1 bar easily. I have the 52mm one and like it.
I have seen brand new Autometer boost gauges out of calibration and other ones that were off by a couple of psi. That is unacceptable to me so I won't buy their gauges just their gauge pods.
Old May 2, 2002 | 11:14 PM
2K_TEG's Avatar
Default Re: Which gauge has a smal scale? ->> (turbod97ex)
If GReddy does make one...I would definately go with them over autometer, even if it does mean you will have to tape a BAR to PSI conversion table on your sun visor.
Old May 3, 2002 | 12:58 AM
01geeser's Avatar
New User
Default Re: Which gauge has a smal scale? ->> (2K_TEG)
omori makes a mechanical boost gauge with increments of .02 kg/cm. goes up to 1.6 kg/cm.
Old May 3, 2002 | 07:47 AM
escapist13's Avatar
Default Re: Which gauge has a smal scale? ->> (01geeser)
Thanks for the replies, but I looked on Greddy's site and all the boost gauges went to 2 bar (basically 30 psi) in 180 degrees. This is the same as the Defi and Apexi ones I dislike because of the scale. Is there a different Greddy gauge that they don't show on their site? Any links to pics of that?
Thanks
Old May 3, 2002 | 08:10 AM
Pritos's Avatar
New User
I'm using a 20 psi autometer. Mine is pretty much right on with my avc-r readings (after conversions of course)
Old May 3, 2002 | 08:54 AM
turbod97ex's Avatar
New User
The Greddy gauge displays differently than what you are thinking it does. It goes from the minimum vacuum to 1 bar of boost in 180 degrees. Yes, it is a 2 bar gauge but it does not get to the 2nd bar until it has gone 3/4's of the dial. Here is a photo of the gauge
I can get you the gauge for $119 plus a few dollars shipping, in either black or white face.
FRernesto
Aug 29, 2007 07:01 AM
BpuTacoma
Dec 5, 2005 05:23 PM
JICsube
Jun 10, 2003 08:24 PM
escapist13
May 2, 2002 07:39 PM
Aeka GSR
Mar 26, 2002 02:12 PM
