Garrett T3/TO4 BB conversion cartridges ?
Hi all , have seen an ad for these at ATP Turbos site but not updated for some time so any links or details ?
Thanks Adrian . |
Re: Garrett T3/TO4 BB conversion cartridges ? (discopotato03)
what you wanna know about them ? they use the same BB cartidge as the GT series. steel dual ball bearing.
. Exceptionally Crisp Throttle Response 2. Spools Up to 15% Quicker than Journal Bearing Turbos 3. Quicker 0-60 Elapsed Times 4. More Tolerant of Marginal Lubrication 5. Less Chance of Seal Leakage 6. Improved Damping & Control over Shaft Motion 7. No Thrust Bearing, which Eliminates a Weak Link 8. Maximum Efficiency, Performance & Reliability at an Affordable Price if you need pricing PM me. its acutally not much more to purchase the complete turbo VS just the center chra |
Re: Garrett T3/TO4 BB conversion cartridges ? (project dc2)
Thanks , I wanted to know what turbine and compressor options are available .
Cheers Adrian . |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by discopotato03 »</TD></TR><TR><TD CLASS="quote">Thanks , I wanted to know what turbine and compressor options are available .
Cheers Adrian .</TD></TR></TABLE> pretty much all the t-series and everything that is available in a journal bearing. I got a P-trim 67mm compressor(T04R). |
Cheers Adrian .</TD></TR></TABLE> as of right now, Garrett has limited the release of the BB chra to only the stg3 and p-trim turbine wheels. but, we can build them with almost any comp. wheel. https://honda-tech.com/forums/images/smilies/emthup.gif im running a BBTO4R with a T3p .63 a/r on my daily driver, and loving the pressure recovery between shifts.... https://honda-tech.com/forums/images/smilies/emwink.gif |
Re: Garrett T3/TO4 BB conversion cartridges ? (PhoenixTurbo.com)
how much for a t3/t4 60trim version?
Re: Garrett T3/TO4 BB conversion cartridges ? (graphic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by graphic »</TD></TR><TR><TD CLASS="quote">how much for a t3/t4 60trim version?</TD></TR></TABLE>
pm sent special pricing til the end of the year on all BB chra's https://honda-tech.com/forums/images/smilies/emwink.gif |
This is really good news - those P trim/TO4R's are the same as the Z by the sound of things .
I would like to see more of Garretts GT plain bearing turbines available with BB's ie the GT32 and GT37 . I like my turbos to have larger turbines in relation to compressor diametres so turbos like the GT3271 GT3576 GT4082 GT4067 could work well . While the TO4P trim seems to work I'd like to know if one of the GT spec turbines could do the same job but with a little less weight so maybe better transients - GT35 or GT37 turbine ? I really hope Garrett releases all the turbines and compressors in BB form and makes them available as spares - as well as rebuild kits . This way we can build what we like and not be limited to the generic diesel CHRA's . Should increase Garretts market share no end . Before I go I've noticed that over there you use the compressers inducer diametre to describe a wheel ie 67 for TO4R , seems opposite of what Garrett does with GT wheels anyway . Last quick Q , When the GT40R was first released the pics of it showed a 6/12 bladed compressor (BCI-18 ?) , the later ones seem to have a 7/14 bladed compressor (C 117 ?) . I always though the lower the blade count the better or has some later tech design got around that , could be some specific diesel app ? Cheers Adrian . |
so can we work a SC63?
I need a new inlet housing do you sell those
