Fully Built R18 Stepping Up
Lets see how this R18 performs cause my plans are to
till it pulls the numbers intended !
Hahaha that said All work is being done by Jotech Performance (Jo) definitely content with the extra effort they put in to pick up customers car!!
Thanks JC!! :clapping: On to the parts!
Engine -
*R18A1 Block
*CP Pistons
*Pauter Rods
*ERL Sleeves (Machine Work)
*Custom Head Studs
*SuperTech Custom Retainers
*SuperTech Custom Springs
*ACL Race Bearings
*Injected OEM Mounts (3M Window Weld)
*Custom Intake Manifold - by Gato Performance
*Thermal Gaskets
*GoPower Cam (still debating)
Transmission - (lets see till when it holds!)
*MFactory Helical LSD
*MFactory FD 4.678
*Clutch Masters 'Stage 4' 6 puck clutch
*Stainless Steel Clutch line
*Hybrid Racing Shifter Bushings
*Hybrid Racing Base Bushings
Forced Induction -
*Jotech R18 Turbo Kit
*Precision 5857 Journal Bearing Billet .63 A/R (debating on buying Str8JDM's 5857 BB .82 A/R)
*DEI T3 Turbo Blanket
*Tial 38mm vband
*Tial 50 mm blow off
*Hondata 4bar Map Sensor
*Skunk2 76 mm Exhaust
*Stainless steel Turbo manifold, Downpipe, Dumptube (Ceramic Coated)
*Aluminum 2.5in Intercooler piping
*Aluminum 3' Inch intake with KN filter
*intercooler
***CMB TUNING***
Fuel System -
*255 Walbro Fuel Pump
*Jotech Fuel Return Kit
*Fuel Injecter Clinic 1000cc Injectors
*All fittings will be AN and Stainless steel Braided lines
Suspension/Brakes -
*Skunk2 Pro-C Coilovers (8k Front, 12k Rear)
*Full-Race Traction *****
*Goodridge Stainless Steel Brake Lines
*ARP Extended Studs
*Hawk HPS Front
Engine -
*R18A1 Block
*CP Pistons
*Pauter Rods
*Custom Head Studs
*ACL Race Bearings
*Thermal Gaskets
*MFactory FD 4.678
Forced Induction -
*Tial 38mm vband
*intercooler
***CMB TUNING***
Fuel System -
Suspension/Brakes -
*ARP Extended Studs
*Hawk HPS Front
Interesting exhaust manifold didn't know r18s where setup like that..new age single cam lol..nice fab work by Jotech,there in central florida I believe..
Got the Turbo kit installed was running stock internals no exhaust etc for ~14k miles. Now going in for the REVAMP 10's here i come!!! complete motor build and starting boost now at 25 psi and working up from there
its gunna be epic! lets see if fully built it out performs on the K20
hahaha High GOALS!
hahaha High GOALS!
Gotcha can't wait for results..girl around here had one boosted by alljap seen it the other day matter of fact, don't know whats going on with it currently though.
Im assuming KT with the White Coupe.
Shes had some issues with shops (AJP,Jotech) and im not sure if her car is up and running but last i heard she was having issues with something.
have you looked into the "window weld" threads... seems like alot of people are having good luck with it... its basically a urethane glue that is used for windshields and you just fill up the mounts w/ it and let it dry...
I remember when I first did a R18 header and I took it out of the box, it looked like a DSM turbo downpipe :p ..... But for what it is, it is putting a impresive number for the psi!!! Good luck and keep us posted!!!!!!
The problem are not going to be at the low boost end with that design but in order to have good scavenging the manifold for that car sucks. Its great for smaller turbo's and immediate results but as soon as you start trying to cram 20+ psi through that its probably going to produce less than optimum results. Right now it looks good because the head can handle the volume of air efficiently.
This is awesome, I have replaced alot of these blocks in the earliers one due to the coolent leaks, glad to see someone making some nice power with them.
There was a Problem with the cast when they were casting from 06-08 a few into 09 before the issue was corrected and the faulty cast changed out. i have a 2010 block 2 years after the correction was made so im sure im good on that. The Torquiest honda block i've seen putting out almost identical torque and horse power. Cant wait to see what she does at 25 lbs +
Anyone here have results from fully building a SOHC Trying to figure out best compression ratio if my stock ratio is 10:5:1 should i drop to 9:5:1 or 9:1:1 or 9:1. Any one have any recommendations with prior real world experience ? was going to decide after i got the block back from ERL see what it comes back bored out and sleeved to.
they give so much play to the engine its terrrible
