Fuel system upgrades....
Old Jan 31, 2004 | 10:34 AM
Team 4R's Avatar
Default Fuel system upgrades....
hi all, i've been doing a lot of research before buying my turbo kit but i have a few last questions.... one of those has to do with the fuel system and which upgrades i should be purchasing for it...... can anyone confirm for me that all i need is a stronger fuel pump and some larger injectors...? i'll be using the aem ems for engine management. thanks in advance.
Old Jan 31, 2004 | 10:43 AM
baphomet's Avatar
Default Re: Fuel system upgrades.... (Team 4R)
Your are right unless you want over ~500 whp.
Old Jan 31, 2004 | 11:18 AM
gritsak's Avatar
ide add in an adj FPR too....if you have the money, do a braided line from the fuel filter to the rail for the feed, and from the rail to an adj FPR then to the stock return hardline...im pretty sure someone on here sell a kit for at least the feed
Old Jan 31, 2004 | 11:22 AM
1fstevo's Avatar
New User
Default Re: Fuel system upgrades.... (gritsak)
why do so if your stock fuel line from the filter to the tank is still the original size?
Old Jan 31, 2004 | 02:21 PM
gritsak's Avatar
Default Re: Fuel system upgrades.... (Evo Hybrid)
just because it looks nicer and you can easily put an aeromotive type FPR on...again i said if you have the money, its not totally necessary.
Old Feb 2, 2004 | 12:27 PM
Team 4R's Avatar
i'll look into it at least..... thanks for the inputs.
Old Feb 2, 2004 | 12:52 PM
g2turbo's Avatar
walboro 255 HP $99
Depending on HP level 550-1000cc injectors $400 roughly
550's are good for roughly 350whp @ stock pressure
1000's can support over 500whp
Steeve_Civic
Aug 7, 2012 05:53 PM
b20vcrxsir
Apr 21, 2009 09:01 AM
TurboEK9Coupe
Jul 24, 2007 02:46 PM
92intb18a
May 28, 2002 08:11 AM
Hispeed
Jul 30, 2001 10:12 AM
