Fuel system for 500-600whp
Old Oct 20, 2006 | 01:44 PM
akira712's Avatar
Default Fuel system for 500-600whp
what's needed for a 500-600whp setup?
new fuel rail, what size ID?
FPR
Change stock fuel lines?
walbro fuel pump good enough?
Old Oct 20, 2006 | 01:56 PM
B18 CYA's Avatar
Don't think a walboro 255lph will work for 500-600whp. If you change your stock fuel lines, you may as well get an external pump such as the SX Performance or the Aeromotive A1000 .
Old Oct 20, 2006 | 02:14 PM
714phil's Avatar
Default Re: (B18 CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 CYA &raquo;</TD></TR><TR><TD CLASS="quote">Don't think a walboro 255lph will work for 500-600whp. </TD></TR></TABLE>
are you sure about that?
Old Oct 20, 2006 | 02:22 PM
F20Cteg's Avatar
Default Re: (STD ONEpointSIX)
For the walbro you need the high pressure one. Most places only sell the low pressure 255.
&gt;&gt;&gt;&lt;&lt;&lt;
Old Oct 20, 2006 | 03:42 PM
Blind-Fashion's Avatar
You need the walbro 255 HP, new fuel filter and 1000cc injectors and you should be good to go. I made 603 whp on that setup
Old Oct 20, 2006 | 03:44 PM
akira712's Avatar
Default Re: (Blind-Fashion)
double post
Old Oct 20, 2006 | 03:45 PM
akira712's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blind-Fashion &raquo;</TD></TR><TR><TD CLASS="quote">You need the walbro 255 HP, new fuel filter and 1000cc injectors and you should be good to go. I made 603 whp on that setup</TD></TR></TABLE>
no fpr, and stock fuel rail?
Old Oct 20, 2006 | 04:04 PM
siblues's Avatar
Default Re: (eastcoast_ej6)
I made a shade under 500 with the walbro 1000cc precisions,fuel lines,and a aeromotive fpr
Old Oct 20, 2006 | 04:06 PM
akira712's Avatar
Default Re: (siblues)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siblues &raquo;</TD></TR><TR><TD CLASS="quote">I made a shade under 500 with the walbro 1000cc precisions,fuel lines,and a aeromotive fpr </TD></TR></TABLE>
Where you limited by fuel or turbo?
Old Oct 20, 2006 | 04:13 PM
siblues's Avatar
It was the head and it was on pump gas so it wasnt pushed to the point of destruction
Old Oct 20, 2006 | 05:48 PM
TIGboy's Avatar
buddy of mine made 575whp on race gas with 950cc injectors and a 255lph so it can be done, but I dont recommend it. he was also at 97% duty cycle.
Old Oct 20, 2006 | 06:04 PM
Black DC2's Avatar
Default Re: (TIGboy)
i made 620 on stock fuel lines and a walbro hp...
Old Oct 20, 2006 | 06:05 PM
SilCiv2K's Avatar
Default Re:
585whp , 1000cc XS regulator 8an lines Walbro 255HP 10guage feed to pump via a relay , held pressure w no problem. Over 600whp would be smart to run a bigger pump, injectors, feed/return line not saying it cant be done- just my opinion.
Old Oct 20, 2006 | 06:06 PM
akira712's Avatar
Default Re: (Black DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black DC2 &raquo;</TD></TR><TR><TD CLASS="quote">i made 620 on stock fuel lines and a walbro hp...</TD></TR></TABLE>
no aftermarket fuel rail or FPR?
Old Oct 20, 2006 | 06:07 PM
Monkeyballs's Avatar
Default Re: Re: (SilCiv2K)
612hp, walbro 255hp, Precision 1000cc injectors, AEM regualtor, stock lines, Edelbrock Rail
Old Oct 21, 2006 | 04:48 AM
akira712's Avatar
what kind of #'s are people making with the walbro 255 low pressure?
Old Oct 21, 2006 | 06:10 AM
Blaze45's Avatar
Brrraaaap!
bump for the same question myself.
Old Oct 21, 2006 | 07:03 AM
banmeagain's Avatar
Default Re: (Blaze45)
there is no need outside of ricer ******ry for an fpr or rail under 600+whp
got cash to blow? do it
otherwise stock system + 255hp with a direct 12v and 1000cc injectors = it
Old Oct 21, 2006 | 07:36 AM
JDMorgan's Avatar
Default Re: (banmeagain)
im supprised nobody made 500-600 hp on 750cc or 800cc injectors.
Old Jul 25, 2008 | 06:34 AM
JDM97R's Avatar
Default Re: (JDMorgan)
530whp stock fuel lines ,stock fuel rail and fpr,single walbro 255hp and rc 750cc injectors with 91 duty
Old Jul 25, 2008 | 07:04 AM
Boostedb20EH2's Avatar
Default Re: (JDM97R)
The normal walbro 255hp can be used. All you need to do is simply add another relay on it. I'm sure a few guys on here know what I'm talking about and can help you.
Old Jul 25, 2008 | 01:15 PM
morgan@synapse motorsport's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM97R &raquo;</TD></TR><TR><TD CLASS="quote">530whp stock fuel lines ,stock fuel rail and fpr,single walbro 255hp and rc 750cc injectors with 91 duty </TD></TR></TABLE>
sorry thats just not possible with 750s at stock fuel pressure.
500 to 600 can definately be done on 1000cc injectors with the 255, if you really want closer to 600whp i would invest in a good sumped tank fuel system.
Old Jul 25, 2008 | 04:24 PM
Muckman's Avatar
Moderator in Chief
Default Re: (mike@synapse motorsport)
Is there a bigger intank fuel pump than the Walbro? I heard Endyn makes a modified Bosch pump that fits in the tank.
Old Jul 25, 2008 | 04:47 PM
95dxsir2's Avatar
Default Re: Fuel system for 500-600whp (akira712)
alright akira, stepin up the power level!
have fun
Old Jul 25, 2008 | 05:02 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Fuel system for 500-600whp (95dxsir2)
it can be done, but at that level, why skimp?
