foil under thermal wrap?
Old Feb 27, 2005 | 03:38 PM
SHystrdyGSRtdy's Avatar
Default foil under thermal wrap?
to further protect my ac lines.. anyone ever thought of putting foil under thermal wrap for even more protection/precautionary methods??
Old Feb 27, 2005 | 04:57 PM
redzcstandardhatch's Avatar
something different
Default Re: foil under thermal wrap? (SHystrdyGSRtdy)
ive used foil for a thermal barrier. works perfect.
i had a coolant line runing kinda over my turbo manifold, and the foil kept it just fine. not i have a "sleeve" heat wrap over it. works great.
Old Feb 27, 2005 | 05:02 PM
Default Re: foil under thermal wrap? (redzcstandardhatch)
hmm.. anyone know how much thermal wrap i need for everything i need to wrap? (not sure exactly what i need to wrap)... the ac lines.. anything else?
Old Feb 27, 2005 | 05:11 PM
oxSLEEPERxo's Avatar
where is the best place to buy thermal wrap for cheap since we are on the topic
Old Feb 27, 2005 | 05:17 PM
Default Re: foil under thermal wrap? (oxSLEEPERxo)
http://www.eastwoodco.com/shop...=3396
http://aircraftspruce.com/menu....html
Old Feb 27, 2005 | 05:21 PM
D-tuned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxSLEEPERxo &raquo;</TD></TR><TR><TD CLASS="quote">where is the best place to buy thermal wrap for cheap since we are on the topic </TD></TR></TABLE>
it got my thermal wrap from summit
Old Feb 27, 2005 | 05:41 PM
Def's Avatar
Def
Default Re: foil under thermal wrap? (2000civicsi)
Put foil on the outside of the wrap. It'll do MUCH more being there.
The short of it is that it is actually a good conductor of heat, but doesn't absorb much from radiation. So having it down at the bottom really doesn't add any insulation at all, but having it on the outside severely limits how much radiation heat energy is reaching the hoses.
Keep in mind there are three forms of heat transfer - conduction(solids), convection(fluids) and radiation(EM radiation, like a heat lamp).
Old Mar 2, 2005 | 06:41 PM
Default Re: foil under thermal wrap? (Def)
so how much thermal wrap did you guys have to use? is there anything else that NEEDS wrapping besides the a/c lines?
totsie7944
Jun 13, 2008 10:15 AM
eagleclawracing
Aug 17, 2006 04:15 AM
9200RPM
Sep 7, 2004 08:31 AM
vtec.dc2
Apr 19, 2003 06:39 PM
cmillz6
May 9, 2002 05:11 AM
