FMIC with oil inside. How to clean it out?
I bought a used FMIC and from the compressor side it has oil residue in it.
What are the best methods of cleaning this out?
Soak it in brake cleaner?
I know some of you have had this issue or seen it. What are recommendations.
TIA
TIA
http://www.awesome-cleaner.com/
Cheap, effective, and environmentally friendly. What more could you ask? Heh.
use simple green form the part store works like a champ just cap one side of the intercooler and pull a gallon in depending on how big the intercooler is then let it sit for a bit and shack it around then drain make sure both sides are caped when shacking it.
Ok how about long term "side effects" of using like gas, brake cleaner and harsh chemicals. Hypothetically saying I capped one end filled with gas and shook the hell out of it and drained it. It came clean. What are some routes to take as far as a final rinse? Will harsh chemicals deteriorate the insides? I have some stuff kinda like the awesome. Maybe I will try that first.
Thanks for helpful responses. Don't normally get those posting in model spec forums.
Will keep posted. are there any write-ups of this or should I document???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeSLO »</TD></TR><TR><TD CLASS="quote">i use brake cleaner for most cleaning needs. spray it in there, don't need to soak. and if you've got an air compressor, a little air pressure wouldn't hurt. brake cleaner FTW</TD></TR></TABLE>
KC GSR
Oct 23, 2003 01:01 PM
