fmic how did you mount yours
Old May 25, 2004 | 01:30 PM
dsm this's Avatar
Default fmic how did you mount yours
im mounting my fmic and i just wanted to know how you guys mouted your..pics would own thx
Old May 25, 2004 | 01:47 PM
kKdARIAN's Avatar
Vice President/CEO
Default Re: fmic how did you mount yours (dsm this)
measure to get perfect center... weld some brackets, and drill.
Old May 25, 2004 | 02:18 PM
VtecDeMoN's Avatar
I don't know how many responses you'll get in this forum but you might want to post this up in the forced induction forum. I'm sure the guys there could help you out too.
Brian
Old May 26, 2004 | 02:51 AM
dsm this's Avatar
yea i posted here cuz i wanted to here from eg guys y0
Old May 26, 2004 | 04:29 AM
monicle's Avatar
Old May 26, 2004 | 06:04 AM
blackeg's Avatar
Default Re: fmic how did you mount yours (monicle)
i centered mine to the bumper support. then i put L - brackets up into the bottom of the bumper support, then i attatched the hangin side of the l brackets to the tabs on the intercooler. i just did it last night so i dont have pics
Old May 26, 2004 | 06:05 AM
silverEH2's Avatar
Default Re: fmic how did you mount yours (blackeg)
i mounted mine on the center of the bumper support, quite simple actually
Old May 26, 2004 | 09:00 AM
T3-T4TEG's Avatar
Default Re: fmic how did you mount yours (silverEH2)
heres mine, it has brackets that go up through the stock holes on the rebar and bolts to the top of the rebar.
Modified by T3-T4TEG at 8:25 PM 5/26/2004
Old May 26, 2004 | 09:21 AM
-iLLuZioN-B18C1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
just like mine.
Old May 26, 2004 | 09:24 AM
spike's Avatar
Default Re: fmic how did you mount yours (-iLLuZioN-B18C1)
I didn't want to weld to my IC.. so i just suppored the two charge pipes that connect to it.
Old May 26, 2004 | 09:25 AM
DD_JonnyLee's Avatar
i just got some L brackets and put them on the top of the i/c to the front of the support, my i/c is kinda low though
Old May 26, 2004 | 09:31 AM
djfob's Avatar
Default Re: fmic how did you mount yours (Raped-Ape)
I uses zipties....I had brackets but cut them off cuz they made my ic fit too low and bumper wouldn't go back on.
Old May 26, 2004 | 09:53 AM
brkrnu's Avatar
Default Re: fmic how did you mount yours (djfob)
I used picture wire and wound it over the bumper support and under the side ports on both sides. Holds up the IC and when the pipes are put on it doesn't move much at all. Can't see it either unless you are down on your knees looking thru the bumper.
Old May 26, 2004 | 11:05 AM
Devine's Avatar
Default Re: fmic how did you mount yours (brkrnu)
i just had 2 aluminum tabs welded on top of my intercooler, than i drilled holes through the bumper support and bolted it on. Also to prevent anyone from being able to steal it i welded the nuts of the bolts to the bumper support
Old May 26, 2004 | 12:26 PM
Nextelbuddy's Avatar
Default Re: fmic how did you mount yours (Devine)
heres mine. i removed the bumper support and used the included aluminum tabs that were already welded tothe intercooler and mounted the intercooler to the bottom of the radiator core support.
Old May 26, 2004 | 12:52 PM
monicle's Avatar
Default Re: fmic how did you mount yours (NextelBuddy)
do you have over heating problems with that setup?
Old May 26, 2004 | 01:36 PM
USDM 4G VTEC's Avatar
heres mine
Old May 26, 2004 | 02:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle &raquo;</TD></TR><TR><TD CLASS="quote">do you have over heating problems with that setup?</TD></TR></TABLE>
nope. air passes through intercoolers jusdt as easily as they do with radiators they can not block air unless of course the fins are clogged up with massive diry and debris....
you can shoot water through intercoolers too you will see that the water just goes right between the fins as if nothing was there.
fastlude69
Jul 14, 2007 08:49 PM
PINKS
Feb 11, 2007 08:11 AM
aaronISthrowed
Sep 19, 2006 08:07 PM
TurBoXBirD16
Feb 16, 2003 02:11 PM
