Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   Flashing Check engine light (https://honda-tech.com/forums/forced-induction-16/flashing-check-engine-light-92753/)
HiGhCaM Nov 23, 2001 01:00 PM
Check engine light flashing?
dbman96 Nov 23, 2001 01:10 PM
Re: Flashing Check engine light (HiGhCaM)
Mine is. Anyone else?
GSRacer Nov 23, 2001 01:20 PM
Re: Flashing Check engine light (dbman96)
me to http://images.zeroforum.com/smile/emsmile.gif http://images.zeroforum.com/smile/embeer.gif
HiGhCaM Nov 23, 2001 01:32 PM
Anyone know the difference betweed flashing and solid on?
VaporTrail Nov 23, 2001 10:08 PM
is it a steady flash, or does it flash long, then short flashes?
HiGhCaM Nov 23, 2001 10:19 PM
Re: Flashing Check engine light (VaporTrail)
Flashes when driving non stop shut car off and its gone then drive more. Easy driving and then later flashes. no codes unless it stays on. usually after flashing is done. and then the codes are 71 through 74 in no partictular order. Is anybody here a Honda Cert Tech?
VaporTrail Nov 23, 2001 10:51 PM
that's a cylinder misfire code. You are either running too rich, or too lean. Check your spark plugs for signs of detonation or other problems with combustion. Make corrections (lowering boost, regapping plugs, adding fuel, taking away fuel) as needed. Then reset the ECU.
FIxALPHA Nov 24, 2001 06:52 AM
Im not here to scare anyone, but I have a couple of questions....
Does your car feel or sound?
Does any smoke come out of the valve cover breather?
This happend to me in the beg. of the season (April 01) on the way home from the track. The CEL started to flash while I was driving and when I shut the car off, the flashing CEL dissapears.
I pulled over to a gas station and saw smoke (white) coming out of the valve cover breather.
The next day took the motor apart and found #3 cyl. with cracked ring lands.
Just wanted to share my story, hopefully thats not the case with your cars.
integRated109 Nov 26, 2001 05:56 PM
Re: Flashing Check engine light (FIxALPHA)
haha, i just did the same thing, but im on cylinder 1. maybe i shoulda listened to all those people that said 8psi was too high on a stock b18c5 http://images.zeroforum.com/smile/emhammer.gif it only smoked that day, but im still getting my misfire codes. just gives ya a reason to build it http://images.zeroforum.com/smile/embeer.gif
