first time using nitrous...need help
i have:
rc 310cc injectors walbro 255lph fuel pump adj fpr msd ignition kit will i need any of these when using nitrous? i'm going to use the msd for sure, but do i need the other parts? i'm going to running a zex kit with a 50 shot on a jdm gsr motor. also, what should the fuel pressure be raised to? i've seen one guy have his at 60psi at idle, isn't that too high? thanks |
Re: first time using nitrous...need help (hondaeg8)
I have ran a 55 wet nx shot on my d16z6 for five bottles, basic mods, intake, apexi N1, straight pipe, etc. Just dont backfire (spray below 3000RPM), it puts be back in the seat
You should be fine with the gsr, mine is a single-cam D16Z6
| All times are GMT -8. The time now is 03:58 AM. |
