A few very wierd problems... some help needed.
Old Jun 9, 2006 | 02:52 PM
BokChoy's Avatar
Default A few very wierd problems... some help needed.
My spark plugs loosen off after a high boost pull... Like finger tight when they're done. Also my compression ratio keeps dropping on my brand new turbo motor... it started at 170 right across the board and 2 of them are down to 125 and the othe ones are at 140... the build is fucked I know, I'm buying another new built block
Old Jun 9, 2006 | 05:00 PM
EG civic's Avatar
Default Re: A few very wierd problems... some help needed. (BokChoy)
Leak down test it, that will tell u a lot more as to what component is leaking. If u r using NGK plugs they are usually torqued to around 20 ft/lbs. Also make sure u r gapping ur plugs correctly.
racin jasin R
Mar 6, 2011 02:03 AM
sneakychaos
Nov 8, 2008 04:47 PM
em1si
Sep 3, 2007 12:23 PM
john d
Aug 22, 2006 08:00 AM
Westrock2000
Jan 26, 2003 09:58 AM
