Feedback request: JDM front DC2/DBM Circuit race tucked radiator options?
Does anybody run a tucked radiator in there turbo road race application? I have been looking at the rywire tucked radiators and just wondering if the are any good. I have a Koyo half size in the integra and it just is not going to cut it. Im leaning towards the tucked radiator because I really don't want to change my turbo set up around to fit a regular full size in it. And If you were able to put a tuck radiator in there did you have to cut the hood latch support? I have a JDM front integra. Thanks
Re: tucked radiator
Originally Posted by jerzey908
(Post 51683026)
The only examples that might really work other than that are a 1990 VW Scirocco,/Corrado (sp?). Or one from CSF. I've never experienced a setup where the hood latch required removal. There is another person (screename "powerless" with his JDM DC2 that was close to using one for his events, but his exhaust manifold (mini-me EQ) allows for it.. I'll see if I can find a link for you. I plan to use a Griffin 3/4 radiator for my mini-we, single back door Garrett I/C. |
Re: tucked radiator
Originally Posted by TheShodan
(Post 51683100)
It's difficult to use a tucked radiator on a road race application, due to the clearance of about 4" needed between the radiator and intercooler, to prevent over heating (unless thou have aero underneath that supplements it)
Re: tucked radiator
(Post 51683151)
I was looking at the ones from CSF. They come in 2 different sizes 24x9and 24x13. I would get the bigger of the two if It will fit.(as in clear headlights, turbo, etc) and both are duel pass. The ones that rywire sell are actually built by CSF. |
Re: tucked radiator
(Post 51683307)
That's no surprise. Time to break out the measuring tape, cardboard, and box-cutters to start your mock-up :thumbup:
An under body air dam may help scoop air to the radiator if you haven't already played with that idea, if clearance becomes an issue in the front to the FMIC. Shouldn't be too hard to mock one up and then cut it out of plastic from Home Depot. |
Re: Feedback request: JDM front DC2/DBM Circuit race tucked radiator options?
so the radiator has to be 4" from the intercooler? if thats correct a tucked radiator will not wpork
(Post 51684586)
so has anybody actually done this with this type of application with success? If so you have any pointers? what worked, what didn't? what did you use for your setup up and any pics so i can get some idea's? Thanks in advance!
(Post 51689087)
I suggest finding "powerneedy's" circuit setup. Check h-t via honda-tech.com for details. |
boosted94gsr has something similar I'm going to copy when I do mine. He cut out the core support on the bottom (which is hollow) and replaced the cutout section with a piece of (1.5"?) angle to be able to fit the radiator under the rad support.
Originally Posted by LightningTeg
(Post 51690588)
I could see that being possible, but I'd avoid it if the purpose is simply for a tucked radiator. |
The pics are pretty self explanatory of what I did, but this is how I got a tucked scirocco radiator to fit under the factory hood latch on my old integra. I’m running the same setup on my current eg civic with it mounted a little different now, but I’ve never had any trouble keeping my car running cool year round. Although I don’t compete in any events that seriously tax the cooling system, just very spirited driving and drag racing. https://cimg2.ibsrv.net/gimg/honda-t...2d8ecbfef0.png https://cimg1.ibsrv.net/gimg/honda-t...a0b5f54856.png https://cimg9.ibsrv.net/gimg/honda-t...bc96f02246.png |
I see. that's not how most people did that when removing the lower support. you simply modified the existing support to work with the Scirocco.. In that case, I think that would be ok to do as an option. So, I recant my previous statement. ;)
(Post 51691536)
But Boosted94GS-R is drag racing. You'll easily upset balance of the front end and will need other means to compensate for the change of mass balance when cornering and cone dodging.
(Post 51691666)
Thats the last thing I'd be worried about. Upsetting the front end? I've removed power steering, A/C etc, added on a turbo and all the required accessorizes etc. Moving the radiator back 2-3" is the least of my worries in that sector. I've been fighting cooling issues with my Integra since I first put a Greddy kit on it in 2008 lol. Been through about half a dozen radiators, wrapped everything, propped hood, heat shields, great fan, triple core rad etc. Just not enough capacity with a half size and the airflow is insufficient through the bumper. We're talking 2-3" here right?
Myself, I'm going to a custom 3 1/4 sized system to work with my 12" high back door Garrett intercooler. |
i was looking at "powerneedy's" thread and Im think about getting the style radiator he did. The Afco Scirocco style if i can get it to fit with out removing the hood latch and re doing my turbo. there are two different ones im thinking about one the core is 2.5" and the other is 2" both are dual pass. just don't know which one to get. here is a link to both https://www.summitracing.com/parts/afc-80107n/overview/ or https://www.jegs.com/i/AFCO-Cooling/...07LWN/10002/-1 |
Has anyone ran a chasebay or speed factory tucked radiator with their JDM Front?
Originally Posted by Cole D
(Post 52032190)
(Post 52033644)
you NA or Turbo?
I don't have a JDM front but, I used a Mishimoto full size (dual core) and titled it forward under the core support. Chopped/capped the filler neck and added a swirl pot with filler neck. Works great with little to no modification to the chassis.
https://cimg6.ibsrv.net/gimg/honda-t...16fa634553.jpg |
Originally Posted by maxwellmercer
(Post 52033739)
(Post 52033651)
Turbo, inline pro manifold and no space up front to run a proper cooling system the traditional way. I've explored the idea of half radiator but I'm afraid it won't be able to keep up in the summer
the inline pro manifold can easily support a JDM front end |
(Post 52033753)
Do you have any pictures of how you mounted it? Did you relocate the bottom mounting tabs?
(Post 52033760)
interesting. I've run similar with both front ends. I have a JDM front end now , and now changed to a full Koyo radiator with twin SpAL fans. but I did change manifolds too.
the inline pro manifold can easily support a JDM front end https://cimg6.ibsrv.net/gimg/honda-t...796bfa767b.jpg https://cimg5.ibsrv.net/gimg/honda-t...6b096b1692.jpg |
(Post 52033786)
I'll post some pics my dumptube runs in front of the manifold and not offset to the side which kills much needed space. I could get a full radiator to fit but no space for a puller fan.
